Notices
Wheels and Tires Post your wheel and tire related questions here.
Replacement Lug Nut
Old Apr 1, 2008
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Replacement Lug Nut
I was in a slight fender bender a couple weekends ago affecting my passenger front wheel area. I went to pull the wheel off to straighten the fender and one of the nuts stripped. After driving around for a while with three lug nuts I bought a replacement wheel stud to get installed, but need to replace the stripped lug nut. I assume I will need to find the exact lug nut if I want to be able to use the key I have for all the others. Is this possible or should I just look into getting all new lug nuts?
Seems like a typical lug nut with 6 grooves:
Old Apr 1, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Replacement Lug Nut
Tuner lugs? If you know what brand they are I'd give em a call and see if there's a way to ID the pattern.
Old Apr 1, 2008
bobsagator's Avatar
They were installed when I got new wheels, don't know the manuf. Was too excited at the time to think one day I might need to know how to replace one.
Old Apr 1, 2008
bobsagator's Avatar
After some searching, it appears that it may be these. Still the question, is it possible to get just one or should I just invest in new all around?
Old Apr 2, 2008
idk, its hard to say for sure if they are the same. i have a slightly used set of 16 chrome muteki nuts and key i will sell you for $25 shipped if you want. i switched to black.
Old Apr 2, 2008
bobsagator's Avatar
I may take you up on those gearbox if I can't find 1 to match the ones I have. I'd just hate to have 19 extra lug nuts that are basically useless.
Old Apr 15, 2008
seelsy's Avatar
seelsy is an unknown quantity at this point
their spline lugnuts made my gorilla, i have the same ones of my rims, any parts store can order you some, most tire shops have um on hand and some will even sell you one
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
Jc20unc
Jan 1, 2002 06:46 PM
Foom
Dec 6, 2001 01:11 PM
