Notices
Wheels and Tires Post your wheel and tire related questions here.
Wilwood BBK and Slicks?
Old Dec 1, 2007
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
Can anyone help me out? I want to utilize this Wilwood Kit i bought but I also want to be able to run slicks at the track 24.5/8.5/15
Anyone get any suggestions? Different size rotor? isnt that what the problem fitting it is? the rotor size or is it the caliper?
Old Dec 1, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Wilwood BBK and Slicks?
Why buy a 12" rotor and then want to run little rims?
You're getting one or the other.
Call Brian at Fastbrakes. He sells a kit that uses a VW Corrado G60 rotor (11") with a wilwood caliper that clears a fair number of 15" wheels. See if his kit uses the same caliper as you got, then get some VW rotors. You'll probably need his bracket to get the caliper in the right place.
Old Dec 2, 2007
RAZRBLD's Avatar
TEIN MAN
well I would be using 17'' for street use... they dont make the slick i want to run at the srag strip that fit 16'' wheels thats my dilema.
Do you think that I really need a Wilwood BBK or Do you think SS lines, Getting Rotors, fluid, New Pads will do the job? Remember I have a K24 swap..with a decent amount of power (279hp 222trq).. Right now my brembo blanks and hps hawk pads are not doing the job.. they worked well when i only had 161hp and 131trq..lol
Old Dec 2, 2007
Jap-Euro Fusion
Power has nothing to do with stopping power. The car weighs basically the same. it takes just as much to stop it from 50 as it did before. The stock brakes couldnt pull it down from 100 no matter how much power it had, so I still, dont see the major point of needing 4 pots. I dont see the need for a huge rotor, other than wasting inertia. 11" brakes (either the Fastbrakes Wilwood kit, DC2Rs, or Legend brakes) ought to scrub off the speed just fine.
Old Dec 3, 2007
Zzyzx's Avatar
Autocross Junky
Um.... Drag racing isn't exactly all that tough on your brakes, so you don't need the greater amount of thermal capacity that larger rotors give you.
Any way, what part of your braking system are you not satisfied with? Do you feel that it takes too long of a distance to stop? are you not happy with the pedal feel? what?
Old Dec 7, 2007
RAZRBLD's Avatar
TEIN MAN
Stopping distance and pedal feel im not satisfied with.
Old Dec 10, 2007
Zzyzx's Avatar
Autocross Junky
Stopping distance = Tire
Pedal feel = Every thing else.
So, for shorter stopping distances you need tires that have softer compounds. So what tires are you running?
For better pedal feel, you need to look in to reducing compliance within the brake system.
Couple of easy things to look at here, such as braided brake lines and Higher coefficient of friction brake pads. other more complex things would be running calipers that have a piston area smaller then the OEM caliper, or going with a slightly smaller master cylinder.
Old Dec 10, 2007
RAZRBLD's Avatar
TEIN MAN
Im now runinng a Kumho ASX 205/40/17
Old Dec 10, 2007
Zzyzx's Avatar
Autocross Junky
I would suspect thats your #1 problem right there.
AXS's are performance ALL SEASON tires with a tread wear of 420... In the racing world we call those rocks. as in the compound is nearly as hard as rocks...
So yeah, you want to stop faster.... buy some good sticky summer tires.
Old Dec 10, 2007
RAZRBLD's Avatar
TEIN MAN
what would u recommend???
Old Dec 11, 2007
Zzyzx's Avatar
Autocross Junky
Welll you were planning on running "slicks" for your drag racing... are you looking to run grippy tires on the street too?
Old Dec 18, 2007
RAZRBLD's Avatar
TEIN MAN
yeah I want to run grippy tires on the street.
Old Dec 20, 2007
Zzyzx's Avatar
Autocross Junky
Just a note, most of the top tier tires have very stiff sidewalls, so they may cause some launch problems if you are planning on using them for drag racing.
other wises... here's a short list in no particular order
1. Falken Azenis RT-615
2. Kumho MX
3. BFGoodrich g-Force T/A KD (Not the KDW)
4. Bridgestone Potenza RE-01R
5. Yokohama ADVAN Neova AD07
6. Hankook Ventus R-S2
7. Toyo Proxes R1R
ect ect ect...
GolNat
Nov 27, 2018 03:32 PM
sf3r8z
Aug 11, 2015 02:32 PM
elitezdc5
May 26, 2015 05:46 PM
HondaLuver
Jan 14, 2003 11:42 PM
drbombay
Feb 14, 2002 07:11 PM
