Notices
Wheels and Tires Post your wheel and tire related questions here.
Are most aftermarket rotors the same size as stock ?
Old Feb 2, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
Looking to replace my rotors on my 02 EX with some aftermarket ones, been looking at these right here
Power Slot ProStop II Rotor
and i was wondering are they the same size as the stock rotor or does it not matter ?
Old Feb 4, 2007
DDragon7's Avatar
You have to get rotors that are the same size.
Since in that link, you already have chosen the vehicle, they should be the right size that they will send you.
Old Feb 4, 2007
JSpec_JDM's Avatar
JSpec_JDM is an unknown quantity at this point
I would say go cross drilled only rather then slotten unless u want to do very fast stopping, slotted eats away at the pads much faster.
Old Feb 5, 2007
vicride345's Avatar
vicride345 is an unknown quantity at this point
I'd say go with the Brembo's they are priced by the pair and for top quality its only $10 more.
Old Feb 5, 2007
Zzyzx's Avatar
Autocross Junky
Actually your rotors have very little if any thing to do with your 60-0 stopping distances...
Old Apr 12, 2009
Zackhx's Avatar
Zackhx is an unknown quantity at this point
Re: Are most aftermarket rotors the same size as stock ?
Unless you purchase some very high Quality cross drilled rotors, they will probably start cracking fairly soon after you put them on. Keep the slotted, they look pretty good, and they are less expensive. If you want even better stopping power you might want some new steel brake lines. Normally the size won't matter in diameter but make sure that they will fit the Caliper, Good Luck!
Old Apr 14, 2009
DDragon7's Avatar
...this thread is over 2 years old.
Old Apr 21, 2009
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
10.4" powerslot rotors.. get them through eddie at TrueHonda (aka thmotorsports) youll get hawk HPS pads and 10.4" slotted/cryo rotors for 203 shipped
Old Apr 21, 2009
cwo715's Avatar
Falken Master
SH*T i didnt realize how old this was
Ninetyatecivic
May 9, 2015 07:48 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
nymbus2k
Dec 17, 2001 04:57 AM
supercivic01
South
Nov 30, 2001 11:27 AM
