K&n air intake
Old Jun 2, 2011
Azulcrema4life's Avatar
Azulcrema4life is an unknown quantity at this point
K&n air intake
Hello, I'm planning to get an intake for my Civic 03 lx, but I'm not sure what to get or what would give a better performance to my car. I'm looking at a k&n 57-3513 fuel injection performance kit gen2 air intake kit or the k&n 69-1008tb typhoon air intake kit short ram. If there is a better choice you knw ur suggestion would help.
Thanx
Old Jun 2, 2011
MindBomber's Avatar
Live for the Twisties
Re: K&n air intake
The fipk has tested better than any other intake on D17s, it's plastic design helps to reduce heat absorbtion and keeps the air entering the engine much cooler. A member gained 4.63hp off one years ago.
You'd be better off buying a cheap ebay intake, putting a good filter on it and using the money you save on the intake to buy a stage 1 cam though. That would give your total hp gain of 20-30hp for maybe $100 more than you would spend on a name brand intake alone.
Old Jun 3, 2011
Re: K&n air intake
for now i want to start with the intake, then the K&N 57-3513, any one has either of them ? any other suggestion? about the stag 1 cam does it affect the civic on the future?
Old Jun 3, 2011
MindBomber's Avatar
Re: K&n air intake
I didn't notice that you had an LX befote, you won't be able to run a stage 1.
If you want to learn more about intakes use the site search, this topic has been beaten to death. The Fipk is the best, the k&n typhoon or the AEM V2 are the second best, any cold air intake is the worst, but overall intakes make your car louder and not much else.
Old Jul 6, 2011
nicko's Avatar
nicko is an unknown quantity at this point
Re: K&n air intake
Ok let me give you some point of views regarding your concern. You may consider both unit. because both are definitely good in performance.
Let start with your first choice
This one could give better performance but it consume more gas
__________________________________________________ ___
This one would give slightly less performance than the first item, but this is gas mileage friendly and likely cheaper in cost.
Well as I said both can be consider. It's is based only in your own preference.
Good Luck!
Old Jul 15, 2011
richs1000's Avatar
richs1000 is an unknown quantity at this point
Re: K&n air intake
Speaking of the K&N typhoon. Has anyone had problems with the hood hitting it? No matter how i adjust it or push the tube down it still hits.
Old Jul 15, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: K&n air intake
I don't know where the hell you get the idea that you will get any kind of performance gains from an intake because you wont... If you do happen to get a K&N your wasting your money because their filter isnt nearly as good as the AEM dryflow. This has been beaten to death as mentioned above. SEARCH The best advice so far is from MindBomber... I think most intakes come in contact with the hood depending on how hard you close it. (on 7th gens anyway)
Old Sep 23, 2011
Lycan's Avatar
Lycan is an unknown quantity at this point
Re: K&n air intake
I kinda have the same problem ... but I don't really care about performance, I only want that my EM2 has a very loud intake sound ... a bit like this:
http://www.youtube.com/watch?v=kbZg8QBJaMM
So, does someone here made any soundclip of his/her intake (on a EM2) ... so I can listen to the sound?
Old Sep 23, 2011
MindBomber's Avatar
Re: K&n air intake
Kenny made a video of what his intake sounds like.
https://www.civicforums.com/forums/1...e-7th-gen.html
Old Sep 26, 2011
Matt300's Avatar
Matt300 is an unknown quantity at this point
Re: K&n air intake
If you really, really need to have a name-brand under the hood, you're better off with the Typhoon. Otherwise I would suggest that you go with an eBay pipe (pipe is a pipe is a pipe) and top it with a good filter.
Put a Typhoon in a friend's 04 Civic. Not much difference, a little gain gas-wise, which was what he was shooting for. Don't expect any significant gains on our engines by doing any exhaust work.
Old Sep 28, 2011
dezod's Avatar
7thgen Power Maker
Re: K&n air intake
Cheapest intakes that still provide some umph and not break the bank.
http://www.dezod.com/pd-kn-57i-serie...-d17-01-05.cfm
or
http://www.dezod.com/pd-dc-sports-cold-air-intakexd.cfm
Old Dec 11, 2011
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
Re: K&n air intake
YES! i had this same exact problem. i cut about .75 inch off the bottom of the intake where it connects to the throttle body. it still hits the hood a little but at least i can get it closed now without bending anything.
Old Dec 18, 2011
ac_2007's Avatar
ac_2007 will become famous soon enough
Re: K&n air intake
Best $45 I ever spent. And this is only half the kit, I chose to keep it a SRI rather than a CAI.
hoofboy
Jul 17, 2015 04:27 PM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
