2002 Civic Ex info./ missing oem accessories and fog light
Old Mar 19, 2011
kickme005's Avatar
kickme005 is an unknown quantity at this point
Does 2002 Civic Ex sedan manual have a vtec engine? where can i get signals for my front fenders? What accessories go in the 2 blank spots by the accessory plug? Also i getting factory oem fog light kit and was thinking the fog switch be better in the spot where the sunroof switch is and the sunroof be moved over by the accessory socket. whats ur thoughts i like accessory. I want to put on factory oem accessory that it did not come with like fog lights anything else i'm missing
Old Mar 19, 2011
MindBomber's Avatar
Live for the Twisties
Re: 2002 Civic Ex info./ missing oem accessories and fog light
Yes, you have vtec.
The signals on fenders are not an accessory, they're an aftermarket or OEM part off a different model.
Moving the sunroof switch would be difficult, but possible if you know what your doing.
Foglights are available on ebay for $30 or at the dealership for around $275.
Old Mar 19, 2011
BlueEM2's Avatar
Whachya lookin at?
What most members do for the foglights is remove the cruise control button from the trim piece, engage the button (so the lights on) and jam it back inbehind the trim piece. Replace the cruise control button with a foglight button
Old Mar 19, 2011
sedan fog switch only fits by the acc socket plug. coupe switch will fit by the moonroof and cruise area. so you would have to order a coupe switch and hardwire it in because the connectors and wires are different. i just bypassed the switch completely so they always turn on with the parking light.
Old Mar 19, 2011
kickme005's Avatar
also in the past , other honda i had w vtec had it labeled on the head vtec. how do make it say vtec? so what is the other spot for by acc plug?
Old Mar 19, 2011
all the EX motor should have "honda vtec" on the plastic wire cover. the LX/DX has "honda" only. you can swap whichever one you want cause they are the same size. i have the honda one on my vtec motor. other spot by acc is for heated seat option in canada.
Old Mar 19, 2011
kickme005's Avatar
ok i see the plastic cover with vtec on it. Is it possible to put a vtec cover on my 1.7 vtec engine like the si 2.0 engine?
Old Mar 19, 2011
lazlong's Avatar
No, it's not the same size. It's has double cams and yours has a single cam.
Old Mar 27, 2011
kickme005's Avatar
is possible to have one made that cover some more in the front to the manifold like the si?
Old Mar 27, 2011
MindBomber's Avatar
Anything is possible for a price, but it would insanely expensive and pointless.
Old Jul 16, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
i find this thread epic for some reason.
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
disaster
Nov 7, 2001 05:30 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
