ep3 door handles
Old Sep 8, 2010
SiR02's Avatar
SiR02 is an unknown quantity at this point
ep3 door handles
does anyone know how to remove the outside door handles on a 2002 civic sir? i got the bolts out and the rods disconnected for the locks and door latch but it seems like something with the lock is stopping me from taking the handle off the door.
Old Sep 8, 2010
02civicsi02's Avatar
Low and slow!
Re: ep3 door handles
This is step by step in the service manual.
1, Remove these items:
. Door panel (see page 20-4)
. Plastic cover, as necessary( seep age 20-2)
Raise the glass fully.
Remove the lock rod protector (A).
-l Remove the screw.
-2 Release the protector from the latch protector
(B).
-3 Pull the protector down to release the hook (C)
from the door.
4. Disconnect the cylinder rod (A),and release the
retainer clip (B). then remove the lock cylinder (C).
Disconnect the outer handle rod (A).
6. Remove the maintenance cap (B),and remove the
bolts securing the outer handle( C) while holding
the handle from outside. Release the hook (D). then
remove the outer handle protector (E).
7. Pull out the outer handle (A), then remove it.
Install the handle in the reverse order of removal,
and note these items:
. Make sure each rod is connected securely.
. Make sure the door locks and opens properly.
. When installing the lock cylinder leave the outer
door handle bolts loose so the inner protector
does not interfere with the lock cylinder
installation then tighten the handle bolts.
. Install the lock cylinder retaining clip on the
handle, then install the lock cylinder. Be sure the
clip is fully seated in the slot on the lock cylinder .
. When reinstalling the door panel , make sure the
plastic cover is installed properly, and is sealed
around the covers perimeter.
Old Sep 8, 2010
SiR02's Avatar
thanks, should have checked my manual but to be honest i didn't think it would be in there.
Old Sep 8, 2010
Low and slow!
Lol its in there. There is everything in there that you need to know.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
JLee93
Aug 21, 2015 05:44 PM
glockma630
Aug 1, 2015 10:30 AM
afinuf12
Jul 28, 2015 04:44 PM
ballmich
Jul 9, 2015 11:59 AM
