Saturday To-DO List
A descendant of 2k1civic.com
Saturday To-DO List
Hey guys. I've got the following planned for tomorrow. Unless it rains. 30% chance.
0. Clean the engine.
1. Install StrutKings shifter cable bushings.
2. Install Intake (Weapon-R Secret Weapon)
3. Clean out any carbon build up in the throttle body.
4. Change Spark Plugs
5. Inspect Belts and Hoses
6. Inspect Driveaxle boots.
7. Replace PCV Valve
8. Clean the air sensors.
Anything else in the area I should check up on?
Any tips before I get started, things I might forget?
I know carb cleaner isn't the best to drump down the throttle body, but getting some down there isn't the end of the world, is it?
Torque specs on the plugs, anyone?
I'm sure they are on the site somewhere, I'll have to search.
Re: Saturday To-DO List
disconnect the battery before you start (write down your factory radio code before you kill the power, if you have a radio with anti-theft)
check all fluids, refill as necessary
if you have time, a brake fluid purge/flush makes the brakes feel alot better.
After you're all done, reconnect the battery and perform the IACV ecu-relearn procedure (start car, verify proper operation, from park rev to 2.5-3k rpm, hold there until fan(s) come on, let idle for 10 min after that. All with headlights/ac/radio/etc all turned off)
Then you're good to go. Dont forget to use anti-seize on fasteners that have torque specs...otherwise it can throw off your torque reading.
If you removed the throttle body to clean out the carbon deposits, and after start up your idle RPM is all over the place, make sure you torqued the throttle body to spec...TB/intake manifold leaks will make the motor to all kinds of weird stuff. It happened to me yesterday after replacing my headgasket; turns out the intake manifold-to-cylinder head was leaking pretty bad. Torquing all the fasteners solved the problem.
Good luck man, have fun
post diy on the pcv valve lol. and get some carb cleaner for the tb and iac. dont forget to do the ecu reset and idle learn when you reinstall em.
Well how did I make out:
0. Clean the engine. Not as good of a job as I wanted to do, but it's better. Here are some before and afters.
BEFORE:
AFTER:
1. Install StrutKings shifter cable bushings. Nope, I forgot to read over the DIY and I remembered when I looked at the cables that I wanted to get new cotter pins, so I skipped this for another day.
2. Install Intake (Weapon-R Secret Weapon) I got it. Had to do some ghetto rigging for the time being, but I will fix that. The sensor was indeed too short and the hose was too small and the support bracket was too flimsy, and I'm short a clamp, but I got it.
3. Clean out any carbon build up in the throttle body. Surprisingly there wasn't anything really in there. I sprayed it down and wiped it, but it was pretty good. I must give my car the right amount of nudging and care to keep it clean.
4. Change Spark Plugs. Did this, but damnit if I didn't break one of the plugs. Just the tip when I was verifying the gap. I hate when I do something so careless. So I'm running 3 new plugs and 1 old one until tomorrow when I can get back to the store and pick up another one. Here is a comparison from old to new:
OLD:
NEW:
5. Inspect Belts and Hoses. Hrm, as I suspected time to change them all!! Look at this crap!! How did my baby get this nasty?!?!
6. Inspect Driveaxle boots. DIdn't get to this, because I ran out of time and didn't want to jack up the car. Plus I noticed the plastic underneath was falling down, so I need to get some clips and I'll do it all another day.
7. Replace PCV Valve. Maybe I don't know where the PCV valve is. I thought it was on the other end of the hose connected to the intake. I guess I was wrong? Anyone know where this is?
8. Clean the air sensors. I sprayed them with MAF sensor cleaner, but there wasn't much to speak of here, they were in pretty good shape.
All in all a pretty successful day, although I ran into some stupid issues. Oh well, I'll fix them.
BEFORE:
AFTER:
OLD:
NEW:
Hehe. Yeah nail it with degreaser first. Honda sells some degreaser/cleaner, or you can get the engine brite stuff. Then spray it off, avoiding electronic stuff by either being careful, or bagging them off. Don't hit any wires or anything or sensor areas with full high pressure blasts, just go slow and be gentle.
Then get the plastics with something, some people use regular dash type cleaner, but I like http://www.trimshine.com/..
*Note. I don't use trimshine on the interior. Although maybe you can....?
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Touge
Sep 23, 2015 11:19 PM
Touge
Ottawa
Sep 23, 2015 11:14 PM
