1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Engine swap
Old Jun 18, 2018
BadFoxDragon's Avatar
BadFoxDragon is an unknown quantity at this point
Engine swap
I recently got an old 1989 Civic Lx (ef body) with the stock 1.5l sohc d15b2 engine. I'm wondrwond what engine I could swap into it easily that would get me a bit more power? I don't mind if I need a new transmission too, just so long as it all just slots into place with nothing major needed.
Old Jun 18, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Engine swap
a d16a6 or imported "zc" engine will drop in with no other parts.
unfortunately, in order to see the maximum performance benefit, you will want to use the intake that comes with the new engine. for that you will need an MPFI computer, injector resistor box, and then you need to rewire the injectors so the car uses 4 injectors instead of the DPFI 2 injector system it has now, and the TPS sensor wiring needs to be switched around because the new intakes throttlebody turns in the opposite direction.
keep in mind that for all the effort, you still will not have a racecar.
This was the sportiest US market Civic, only available as a hatchback. The engine fitted was the D16A6 16-valve SOHC with 4-point injection and output of 108 hp (81 kW). It weighed in at 2,286 lb (1,037 kg), achieving a factory 0–60 mph of 8.1 seconds; and a quarter-mile time of 16.2 at 82 mph (132 km/h).
DeeRod
Sep 28, 2016 09:15 PM
mattcoun
Apr 28, 2010 02:09 PM
LOWPROFILECIVIC
16
Mar 20, 2009 12:02 AM
SUN8637664
Oct 1, 2007 04:58 PM
imported_TunerX
Buy, Sell, & Trade - Archive
Feb 26, 2006 10:05 PM
