My 93 civic hatchback clutch doesn't have much pressure at all. It does release back after engaged, except right after bleeding it for a couple pumps. I tried bleeding the line with the slave cylinder and had no air bubbles coming out, just liquid that looks clean. The slave cylinder also squeaks as the clutch is engaged. I moved away the protective rubber boot and tried seeing if there was any liquid that would come out of the line connecting to the slave cylinder--nothing. Can't put into gear when car is on and can when car is off.
Any suggestions?
Any suggestions?
Bleed the master cylinder with this. Connect the power bleeder to the clutch master cylinder reservoir with a cap from the junk yard or make one with a pvc cap from a hardware store. Done deal. You likely have air in your line.
Thanks for the suggestion. I appreciate the time
