1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Overheating issue
Old May 20, 2014
zemerin's Avatar
zemerin is an unknown quantity at this point
Overheating issue
A while ago my car a couple of times would overheat after an extended period of driving (like an hour give or take). Normally I don't drive this long on a daily basis.
Now the issue seems to be a little more persistent. Putting the heat on full blast normally buys me time until I get home (normally; tonight when I was coming home from a friends house the car started to overheat it didnt help too much). I checked my fan and it seemed to be working fine, so I crossed that out of the possibility of issues, even though if I drive fast enough the car cools down a little.
I don't notice any coolant leaks but I do notice I have to keep filling it up every once in a while. My guess is that its either a thermostat (which I doubt) or the radiator is almost done for (leaning towards this). I doubt its the water pump but I'm willing to guess anything at this point.
Any suggestions? Car is a 1.6 honda civic.
Old May 20, 2014
GolNat's Avatar
Prelude Owner
Re: Overheating issue
When you fill the coolant up does the car still overheat?
It's going somewhere, either from leaking out or burning (head gasket).
Old May 20, 2014
zemerin's Avatar
At around 7 yesterday when I stopped the car after it overheated I topped it off, let the car cool for around 2-3 hours. As I was driving home about 20 minutes later it started to overheat again. So the answer to that question would be yes sir.
I drove it today for like 10 minutes it seemed fine, even though when I looked at my rad it wasnt exactly full. My reservoir is always full though.
Old May 20, 2014
zemerin's Avatar
Old May 20, 2014
GolNat's Avatar
Prelude Owner
Head gasket!
Old Jun 11, 2014
PhillySpeeds's Avatar
PhillySpeeds is an unknown quantity at this point
My Coolant will never stay put.. my water pump and thermo are totally fine but i've got a lot of work to do
Old Aug 10, 2014
Rhonda1's Avatar
Rhonda1 is an unknown quantity at this point
Pull your oil dipstick and look for white mucus film. This will indicate head gasket issue. Check for exhaust smoke as well. Another thing you can check for is a old coolant hose which could be collapsing and causing all the coolant to overflow and spill out while driving. I would fill the car up to level on coolant and park it somewhere. Take some cardboard that is clean and slide it under the engine. Start the car and run it till the coolant fan comes on (maybe 30min). Inspect for leaks. Hope this helps.
thana
Jun 15, 2020 07:05 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
