1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 civic ex won't start
Old Feb 28, 2013
bigsarg69's Avatar
bigsarg69 is an unknown quantity at this point
Question 94 civic ex won't start
I have a 94 honda civic ex, that will not start. It was running tuesday, parked it after a short trip to the store, wednesday morning it wont start. It turns over but will not catch. Fuel pump comes on and has fuel at the rail. Distributor swapped, plugs replaced, main relay tested and swapped with one from running car. Ecu swapped with one from running car, it worked in other car so put back in mine and still nothing. Fuses test good. What could it be?
Old Mar 17, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: 94 civic ex won't start
Sounds like the crankshaft or camshaft position senor has died and isn't allowing the car to start.
http://www.ehow.com/way_5471047_do-c...on-sensor.html
http://www.ehow.com/how_6941010_test...ultimeter.html
Old Mar 19, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Any update on this?
Old Mar 31, 2013
bigsarg69's Avatar
As for the crank position sensor the 94 civic incorporates it in the Distributor the following is the test. it has been completed and the ECU was tested with a known good one. Still no start. Completely frustrated now.
• Disconnect the 8pin connector from the distributor
• Measure the resistance between sensor terminals B & F (ECU terminals B15 BLU/GRN wire & B16 BLU/YEL wire)
• If the resistance is not between 350Ω & 700Ω replace the distributor.
• If the resistance is between 350Ω & 700Ω - Check for continuity to body ground on both B & F terminals.
• Does continuity exist
Yes - replace distributor
No
• Test the ECU
Old May 4, 2013
korthos's Avatar
korthos is an unknown quantity at this point
Did you check to see if the timing belt is still turning the cam? You can either take the dist cap off and watch the rotor button to see if it spins while someone cranks the engine over or take the upper timing cover off and see if it spins there. make sure to crank the engine over though. Just because the belt has tension does not mean it is good. sometimes the teeth come off the belt and visually the belt looks ok from the top
Braun
Apr 23, 2015 09:03 PM
Richkid23
Apr 19, 2015 12:53 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
