1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Idle problem
Old Feb 8, 2013
Efhatch89's Avatar
Efhatch89 is an unknown quantity at this point
Idle problem
Ok before you guys say search I've looked and have been for the past 3 days. My problem is when I leave it in park or put it in neutral my car starts surging. It even does it if I let of the gas going down the road. Now if I'm at a stop and it's in gear it dont surge or if I'm getting on the throttle. I have cleaned the idle control valve and cleaned the throttle body so far what else can be done?
Old Feb 8, 2013
Re: Idle problem
SWAG: It's idling too fast for some reason. Figure out why.
I have no clue what your engine is equipped with, so here's a few ideas
IACV hot with coolant flow? FICV hot? (I have seen them not get hot because of junk clogging the coolant hoses and fittings, this lets them run in cold engine mode--high idle.)
Either one leaking air?
ECT sensor accurate?
Vacuum leaks?
Old Feb 9, 2013
Efhatch89's Avatar
Re: Idle problem
Ok my idle control valve is staying cool and I just bled the radiator system. Still no luck
Old Feb 9, 2013
Re: Idle problem
Then it sounds like the little coolant hoses will be clogged somewhere, no coolant flow through the circuit.
FICV (fast idle control valve) operation depends on having hot coolant flowing through it as the engine warms up so it can control the fast idle speed. If there is no hot coolant flowing through it, it thinks the engine is cold and keeps the speed up accordingly.
You can plug the air passage in the throttle body neck with your fingers to see if the idle speed drops, that indicates the valve is open.
A clog or restriction can happen dang near anywhere along the routing of those small hoses. It doesn't take much to screw up the works.
Last time I had one like that, the clog was inside the steel nipple that sticks out of the cylinder head. Used a drill bit to clean it out, and it looked like a mix of rust and stop-leak that came out of it......
You have to take apart the hoses and stuff so you can figure out what part has blocked flow.
I disconnect one of the small hoses from a fitting (doesn't matter where, but only one), cork one end with a finger, and squeeze the radiator hose.
If coolant squirts out of the open end, that side has flow. Cork that side and squeeze again, there probably won't be a squirt.
Continue this process until the clog area is narrowed down and located.
HTH
Old Feb 9, 2013
Efhatch89's Avatar
Re: Idle problem
Ok I just checked again and the the idle control valve was hot. Anyone else got a idea?
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
