1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
dash cluster swap???
Old Jan 21, 2013
90_civichatch's Avatar
1990 Civic Hatchback
90_civichatch is an unknown quantity at this point
Hey all.. im new to all of this.. I just got a base model 90 Honda civic hatchback the dash cluster is missing the gas needle andthe needle for the temp gauge... will a cluster out of a 89 crx si work? It has a rpm gauge on it and mine doesn't. . Are they the same size? Also is it possible to put a 5 speed manual trans in it? If so where could I find it? Thanks...
Old Jan 21, 2013
clpowell's Avatar
clpowell is an unknown quantity at this point
Re: dash cluster swap???
i think both may be possible. In the 5th gen the clusters were the same plugs and one with a tach in it worked on one that did not come originally equipped. As with most vehicles it is also possible to switch in a manual in the place of an automatic. unfortunately it is almost never plug and play. It takes hard work and a lot of effort to make the transition. Luckily you are probably not the first to try it. I am sure if you do some searches you can find advice on tranny swap.
Cheers
Old Jan 21, 2013
Thanks... my actually has the 4 speed manual trans in it now... I'm not afraid of the work it will take to swap out trans but I can't seem to find any...lol
fatih717171
Jul 25, 2016 06:22 PM
mjdiaz89
Jun 21, 2016 09:26 PM
theteju
Aug 5, 2015 06:59 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
fatih717171
Jul 8, 2015 12:14 AM
