1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 window problem
Old Nov 6, 2012
wood70's Avatar
wood70 is an unknown quantity at this point
95 window problem
95 civic
none of my windows will go down.. it doesn't sound like any power is getting to them I checked all the fuses under the dash. My fuse door is gone so i checked them all because i don't know which one it is. they all looked good. Where else do i look?
any ideas?
Old Nov 6, 2012
Re: 95 window problem
Turn the key on, hold the window switch down, slowly open the door and swing it wide open. Maybe it has wires broken in the jamb harness. If it does anything when you try this, then you have wiring problems and none of what I typed below will do you any good.
Voltmeter checks:
Fuses 24 25 26 28 in the engine compartment should be HOT with the key in the ON position. Yes or no?
No: Do P/W relay pinout tests.
Yes: Remove the master window switch set.
Test for power (B+) at the green/white wire in cavity #7 and test for ground at black wire, cavity #2.
Yes or no?
If either are no, then you have wiring problems.
If yes, Then proceed to window motor wire voltage checks.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
beveragemp
May 25, 2015 07:11 PM
timpan
May 18, 2015 07:06 AM
