1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
93 honda civic dx
Old May 6, 2012
shocker1994's Avatar
shocker1994 is an unknown quantity at this point
93 honda civic dx
how to change the tranny fluid and what kind in a 5 spd manual
also how to put fog light on it i see no spots
Old May 7, 2012
TrikzLane's Avatar
TrikzLane is an unknown quantity at this point
Re: 93 honda civic dx
The manual transaxle has drain and fill screw plugs. The drain plug is on the bottom, the fill plug is on the side. Each can be recognized by the square inset, which fits a 3/8 drive extension.
Always remove the fill plug first, to be sure you can, before removing the drain plug. Just drain the oil, put the drain plug back in, and fill the gearbox through the fill hole until it starts running back out. Put the plug back in. (Warning - the stuff is messy and stinky. Be sure to catch the excess.) Use only Honda MTL. Some have reported good results with Redline but Honda is the safe way to go.
and is it a 2/3dr or a 4dr? but either way, you'll most likely have to take off the bumper and there should be holes to screw the fogs into, once you find them, you'll either have to get a jdm bumper with the holes for the fogs, or you'll have to cut holes for the fogs, which, unless you're a master with body work, can be a risky task.
Old May 7, 2012
i mean whats a good mileage to change this also where can i get this oil
Old May 8, 2012
TrikzLane's Avatar
you can get the oil here http://www.inlinefour.com/honmantranfl.html
change your trans fluid between every 10K-30K miles, or annually if thats easier to remember
jessicakaybby
Apr 20, 2015 12:11 PM
