1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
re-build engine kit
Old Jan 27, 2012
fishdip's Avatar
fishdip is an unknown quantity at this point
re-build engine kit
Hey looking to re-build the engine on my 95 honda civic ex 1.6l vtec. Not looking to make more hp just looking for a rebuild kit that has all the stuff I need for this task. Any ideas on a good place to get this and what all to look for in a kit is greatly appreciated thanks.
Been looking at kits like this:
http://www.nopi.com/dsp_parts.php?vsubpcdesc=Engine Compartment | Engine - Rebuild Kit
BRONZE KIT - D15Z1 - 16V - SOHC Vtec - Contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable) and a set of expansion plugs - Also contains oil pump and water pump
Mfg# EKH21VB, NOPI# 102+0988
Old Jan 28, 2012
Re: re-build engine kit
Link fail.
I bet you can get a used engine cheaper than rebuilding one.
Old Jan 29, 2012
fishdip's Avatar
Originally Posted by ezone
Link fail.
Thanks for the reply ezone. It wont let me post to the part on the site but do you know if this site is a good one? Also I want to learn how to do it I dont really care about the money part of it to me its the knowledge I will have frome doing this.
Old Jan 29, 2012
I know absolutely nothing about the seller you linked. I work for a dealer.
Does it have a real problem that would warrant a rebuild? Will the rest of the car last long enough to warrant a rebuild?
Does it even make economic sense?
If it hasn't lost any bearings, I might just re-ring and re-seal it. Cheaper and same amount of work.
Strip it apart and see what it really needs before buying anything.
Old Jan 29, 2012
fishdip's Avatar
Economic sense probably not lol. The rest of the car for the most part is in really nice shape it dose leak oil but only a little bit but that is all. Other then that I just want to do it for the hell of it lol.
Old Jan 29, 2012
Why not fix the leak and just keep driving?
At that age, the rubber gaskets should be hardening up.
Old Jan 29, 2012
fishdip's Avatar
I like playing with stuff lol Plus it be fun.
Old Jan 29, 2012
BlueEM2's Avatar
Whachya lookin at?
Sounds like a fun project, also a big job. If you do tackle this make sure you know what your doing and don't miss any steps.
Old Jan 29, 2012
fishdip's Avatar
Thanks blueEM2 I have no clue what I am doing this is why I want to do it lol I have a few vids I have found of others doing it and a few books on it tho. it may start out fun but after doing it I may want to
Old Jan 29, 2012
Make sure you have other wheels to drive, it's going to be apart for a long time.
Old Jan 29, 2012
tell me about... having another car helps a ton! no hassles when things are... frozen in place for years...
yeh can start looking in here, this is where i got my timing belt/head gasket parts from - OEM, not so much diff price from others
http://www.hondapartscheap.com/index.php?p=home
Old Jan 29, 2012
fishdip's Avatar
I have a few other cars so its ok as far as that. Thanks for the link also gave you some rep for it.
Old Jan 30, 2012
BlueEM2's Avatar
Whachya lookin at?
I'll give you some advice... I don't know your mechanical background so I'll tell you this. Start with smaller stuff, see how fast you learn/adapt to working on the car and see if you feel comfortable driving something youve worked on. I started by changing oil, brakes, spark plugs and that kinda stuff. Later on I moved to ball joints/clutches and eventually a head gasket job. It's important that you feel comfortable driving something youve had in pieces because that is what deters most people from working on their own cars.
Jumping into an engine rebuild is not a good method of learning and will usually end up costing you large cash and wasted time because you won't be able to reassemble it.
Old Jan 30, 2012
fishdip's Avatar
Thanks for the reply blueem2. On a 1-10 scale im at a 6 oil change brakes that sorta stuff is a 1 I replaced the valve stem gasket and that was a 3 as I broke 2 old bolts and had to drill them out and re tap. I am ok with driving it after working on it. If it blows up Id still be ok as I can pay to get a used one. Looking at how to do it for the most part I can take a toneof pics and if need be I know a few guys in the loveland area that be able to help me if I am stuck
Old Feb 22, 2013
Arcaneshotatx21's Avatar
Arcaneshotatx21 is an unknown quantity at this point
hello everyone i have a 95 civic 1.6L vtec D16Z6 SOHC and im new to tuning so what is the first step into fixing up my motor its 125HP stock Pls help an im on a low budget
sysblack
May 13, 2015 08:55 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
zack22490
Apr 29, 2015 03:17 PM
cloudguy
Apr 28, 2015 05:02 AM
supercivic01
South
Nov 30, 2001 11:27 AM
