1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
How to Find the Check Engine Light Code on a 1988 Honda Civic
Old Dec 6, 2011
lionel_lampkin's Avatar
lionel_lampkin is an unknown quantity at this point
can anyone please tell me how to locate and read check engine light code?
Old Dec 17, 2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
Re: How to Find the Check Engine Light Code on a 1988 Honda Civic
92-95 Accord, Civic, Civic Del Sol and Prelude
Retrieving Codes
With ignition off, insert jumper wire in service check connector terminals, located behind right side of dash on Accord, Civic and Civic Del Sol and near center console on Prelude.
Turn ignition switch to ON position. Diagnostic Trouble Codes (DTCs) will be indicated by a series of long and short flashes on MIL.
The number of long flashes indicates the number in the 10s column. The number of short flashes indicates the number in the 1s column. For example, 4 long flashes followed by 3 short flashes would indicate DTC 43.
http://www.troublecodes.net/honda/hondadtc.shtml
Link is the codes list. The jumper wire isnt anything special. Most of the guys i know and anyone on here whos not half dumb will use a paper clip.
Old Dec 17, 2011
88 probably has an LED on top of the ECM that blinks out a 1 or 2 digit code when you turn the key on.
The CEL does not blink out the codes, the LED does.
Pull off the right door sill molding and small cover on the kick panel, then pull down the carpet from under the dash to see the ECM. Turn key on, count flashes.
Old Dec 17, 2011
MrDobin's Avatar
Oops. Didnt read the year haha.
Old Jan 3, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Pull up the carpet on passenger side footwell, turn key to on, count blinks of red light on ecu.
Old Mar 19, 2012
Thank you for your reply, but I've been all around and back again with this thing and I can't find the ECU to save my life. I look on the right side under the carpet and zealtch. And now I'm having another issue, I'm not sure that it's related or what but after turning the car off after a long drive the car wont start til I allow it to sit for a few minutes. Does any one have a cure other than scrapping this gas saver. Please advise.
Old Mar 19, 2012
Found the check engine lights but not sure what I'm reading the 1st set of lights was 16 and second 19, please advise.
Old Mar 19, 2012
Old Mar 19, 2012
lazlong's Avatar
code 16- fuel injector(s): With the ignition OFF, check each injector for resistance. You should get 1.5-2.5 ohms.
EDIT: code 19 is the Automatic Transmission Lock Up Control Solenoid- still researching...
Xuhme
21
Aug 7, 2023 03:40 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
