1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
engine wiring problem
Old Oct 21, 2011
blasianboy's Avatar
blasianboy is an unknown quantity at this point
ok, just swapped out a 93 DX coupe engine with a 97 engine. Can't figure out the wiring as the 97 is different from the 93. Is there a wiring harness already built? Need help!
Old Oct 21, 2011
lazlong's Avatar
Re: engine wiring problem
Yes, it's called an OBDII to OBDI jumper harness. Also, depending on which swap you do, you may need to re-wire the distributor.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
McD
Apr 16, 2015 10:46 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
