1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Air air air
Old Sep 8, 2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
Air air air
I believe I have this diagnosed... but you guys can help confirm and save me a headache.
Did a coolant change this morning and when i went to take a test drive I came home and discovered air coming from my oil cap, took cap off and its a solid stream of air/exhaust smelling crap. I though initially "oh **** its a gasket" being i was abused by an old caddy with such, but my shop said doesnt sound right given symptoms.
As of now the symptoms are air out the oil cap/top and off idle despite timing being correct and idle valve cleaned and idle set. I am hopin i am just suffering a clogged pcv/egr but not dealt with this enough to know. can anyone shed light? thanks. Oh btw no coolant loss and no oil coolant signs whatsoever, or overheating.
Old Sep 8, 2011
MrDobin's Avatar
Re: Air air air
So an update, I had to top off the coolant and adjust the idle so thats a non issue. The oil by the way is not burning, going down, or smoking. I did a bunch of browsing about the "air oil cap" etc and found its not at all uncommon, it seems. I have a light suction, NOT blow out, correction there. I cleaned all valve lines pcv etc and nothing. I figure with so many having this sign while the engine is running, not worried for now.
For good measure I marked the coolant level in the reservoir to see. Who knows
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
NoobyKid
Jul 13, 2015 07:53 AM
