1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
new upper balljoint/control arm.. alignment?
Old Apr 13, 2011
laack's Avatar
laack is an unknown quantity at this point
94 civic dx, mt, 230,xxx
I'm replacing only the upper ball joint and control arm as the come pre-assembled for nearly the same price as just a ball joint.
Do i need to do an alignment replacing these parts only, the rest of the front end will stay untouched.
I don't have much money to spare, can anyone review either dorman or autopart international control arms? I will spend the $ for moog if i have to, but it takes a big bite out of my already too small budget!
Old Apr 13, 2011
MindBomber's Avatar
Live for the Twisties
Re: new upper balljoint/control arm.. alignment?
Yes, you absolutely should have an alignment done after replacing a ball joint.
If your on a tight budget then take it for a drive on a good road and if it's not pulling to hard to either side then you should be okay delaying it for a bit, but the affected tire will probably still wear pretty quickly.
Moog are excellent quality, I would pay a bit extra for them if your planning on owning the car for another 50k miles, but if not then you could go with the less expensive part. Also, I wouldn't replace the control arm, save your money and just do the ball joint.
Old Apr 13, 2011
laack's Avatar
Ive done the lowers with no issues, however heard that the uppers are substantially more difficult and the better option is to replace with the whole assembly. do the uppers press out just as easily as the lowers? is it more of an issue of workable space with the c press in the housing?
Old Apr 13, 2011
laack's Avatar
94 dx upper balljoint
do they press out? are they welded in?
Old Apr 13, 2011
MindBomber's Avatar
Re: 94 dx upper balljoint
press out.
Get a haynes manual and it will have complete instructions on how to change them, I can't find a DIY online to link you too. The press you need can be rented free at most auto-parts stores.
GolNat
Nov 27, 2018 03:32 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
