1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Fuel Injector Help
Old Feb 28, 2011
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
Fuel Injector Help
Okay so I got a list of things I am adding to my rebuild. I keep running across the injector size. D16z6's injectors are 240cc right? Well I was wondering if I should get a bigger injector size, since I am going performance wise. I am not going the Turbo route, But Nitrous in the long run. So far I got these parts
Stage 2 Crower cam
High Compression(milled head, about .010 off)
Flat bottom Ferra Valves
Titanium retainers
Zex Springs & seats
Valve Guides
(Thats about it for the head)
Edelbrock Performer X intake
I also got
May go +.20 on the pistons, depending on block condition.
Pistons
Rings
Bearing
Eagle H beam Rods
Stage 3 clutch & pressure plate
Light weight Chromoly Flywheel
along with some other things that dont really matter for fuel consumption.
I was thinking since I am upgrading to a Stage 2 cam, Perhaps a few more cc's for the injectors? Not only that, But what if I must bore my engine out. Wouldn't it be smarter to have the oversized injectors? Also, If I do get oversized injectors, do I need to get anything to remap my fuel intake? Or will the ecu automatically detect how much cc's of fuel are being pushed into the engine and mix it correctly, Air:Fuel. Or, Once I get my engine rebuilt, should I take a chunk of change and buy one of them fancy Tuners? :P Hondata or some other one. (I know that will be the last step, to the finish. Honestly, wanted to buy a laptop just for my car, since I got it)
SimpleUser
Apr 24, 2021 02:54 AM
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
