1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
need some help for 95 civic
Old Jul 28, 2010
liyan1430's Avatar
liyan1430 is an unknown quantity at this point
Question need some help for 95 civic
hi everyone, im new here, but i need some help from u guys now,
my engine check like is on (the yellow one), it glitter code 6 and 8, which means the coolant temp. sensor and top dead center sensor got some problems
can someone tell me where is the top dead center sensor locate at? is better with a pic. ,
thank you
Old Jul 28, 2010
lazlong's Avatar
Re: need some help for 95 civic
I think it's in the distributor. If I'm not mistaken it's in the bottom next to the shaft seal.
Old Jul 29, 2010
liyan1430's Avatar
ok, im going to try tmr than, thx alot~~~
Old Jul 29, 2010
02civicsi02's Avatar
Low and slow!
It is located in the distributor. Though I think its not replaceable, I think you will have to buy a hole new distributor housing but you will still be able to use the ignition coil.
Old Jul 29, 2010
liyan1430's Avatar
so do i hv to buy a new one from honda dealer or i can buy a new one that is aftermarket, how much are they?? and howz the quality of the aftermarket one?
also do u know about code 6?? the coolant temp. sensor?? where is it?? i think there are 2 or 3 coolant temp. sensor, so which one im going to look for it?? plz tell me, thank you
Old Jul 29, 2010
Low and slow!
You can use one of the aftermarket ones they should do fine. The distributor housing should run you bout 100-150 or so. And for the coolant temp sensor, it is probably somewhere near the thermostat.
Old Jul 31, 2010
davincubus's Avatar
davincubus is an unknown quantity at this point
I just bought a new distributor (TD42U) w life time warranty for my 95 EX on eBay for 100bux. I'll let you know how well it works when I get it.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Be sure to call Honda 1st, give them your vin to verify the model # of what distributor your car needs.
02civicsi02 is correct, the coolant temp sensor is right next to the thermostat and mine required a 24mil long socket to change myself. I tried a used sensor and didnt work. A new sensor at Advance is $50.
Hope this helps!
Old Aug 5, 2010
nerofotia's Avatar
nerofotia is an unknown quantity at this point
Hope this helps!
Yeah; I replaced the coolant temp sensor in my 95 EX a couple months ago. DEFINITELY need the long socket to get the old one out. Otherwise a piece of cake to do- and I'm a newbie to working on cars.
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
