1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
b18b problem
Old Jan 21, 2010
eoracing's Avatar
eoracing is an unknown quantity at this point
b18b problem
i have a problem with my 92 b18b. its jdm and ive replaced the map sensor, o2 sensor, injector seals and i still run like theres vaccum leak. i tried spraying brake cleaner to see if i could find a leak but found nothing. it only does it once it warms up a little bit. i need some help with this.
Old Jan 21, 2010
Travispatoka's Avatar
Travispatoka is an unknown quantity at this point
Re: b18b problem
what exactly is it doing when you say its running like a vaccum leak their is multiple things vac leaks could do
Old Jan 21, 2010
eoracing's Avatar
Re: b18b problem
the idle surges up and down from 2500 to 900 rpms. i think i might have it figured out but any advice is appreciated
Old Jan 22, 2010
Re: b18b problem
are you using the right throttle body? usually tps sensor problems will cause idle surge if you dont have any vacuum leak. is your pcv valve clean?
Old Jan 24, 2010
eoracing's Avatar
Re: b18b problem
well it wasn't always like this, when we first dropped in the engine it ran great until the snow came and **** started to hit the fan. i'm going to swap intakes off of my jdm engine and see if that does the trick. i'll also clean my pcv valve because it's different on the jdm b18b than the usdm. but worst case scenario is my nuts were over torqued and cracked my intake and gasket =( gunna swap intakes and do a full clean up and see if that helps.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
