1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Clutch Going to the Floor, Not engaging
Old May 14, 2009
pvd95's Avatar
pvd95 is an unknown quantity at this point
My clutch is currently going to the floor with very little pressure. It will not engage Gears. So its refusing to go into 1st gear. It can't be the clutch I just put an exedy stage 1 in not even a month ago. My buddy said that it can be the slave cylinder. What can i do?
Old May 14, 2009
bcmedic13's Avatar
bcmedic13 is an unknown quantity at this point
Re: Clutch Going to the Floor, Not engaging
Check the level of hydrolic fluid in your clutch master cyl. you might have a leak with the slave, peel back the rubber piece on your slave and see if it is leaking, becareful, the brake fluid that your system uses is dangerous, if your master and slave are leak free and full of fluid, there might be air in the system wich will need to be bled, if no luck with either, you might have a broken spring on your cluch preventing movement.
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
powman02
Sep 15, 2015 07:38 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Klame9420
Sep 7, 2015 10:03 PM
