1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 Civic DX engine stalled while driving- Help
Old Sep 14, 2008
Larry S's Avatar
Larry S is an unknown quantity at this point
My 95 civic dx, engine stalled while driving and will not restart. The engine will turn over fine. It stalled shortly (as in seconds) after turning on the headlights. It stalled without warning and was running fine up to that point. No, I did not run out of gas. Any ideas?
Old Sep 18, 2008
jm483's Avatar
jm483 is an unknown quantity at this point
Re: 95 Civic DX engine stalled while driving- Help
My DX sort of did the same thing except for the lights killing your engine... My problem turned out to be the fuel pump.
Old Sep 29, 2008
JDMCivic95's Avatar
JDMCivic95 is an unknown quantity at this point
Hey, what motor do you have? Is it manual or automatic? Try checking all your fuses, under the steering wheel as well as fuse box underneath the hood near the battery, make sure none are blown. Check to make sure weather the battery is getting charged by the alternator, and the battery is good...check your fuel filter, it might be clogged it will run but stop shortly and stall out...let me know, might have couple more ideas.
Old Sep 30, 2008
red1995civicdx's Avatar
red1995civicdx is an unknown quantity at this point
Mine Did That A Couple Of Days Ago>>> It Was A Bad Coil In The Distributor
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
