1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Car Dies After Starting
Old May 13, 2008
TurboB20's Avatar
TurboB20 is an unknown quantity at this point
The car is a 1994 Civic EX 5 speed. Body has 230,000 miles on it, 150,000 on the motor. Which is a D16Z6 SOHC VTEC.
What is doing is dying after being started. It starts up great, and then proceeds to idle great too. But after idling for around 30-55 seconds, it instantly dies. Start again dies again same way.
What could be causing this? maybe fuel pump bad? ignition?
Any help appreciated greatly
Old May 13, 2008
Re: Car Dies After Starting
faulty idle air valve or fast idle thermo valve?
Old May 13, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
My parents had this issue 2 months ago. The fuel pump was getting power and you could hear it coming on but there was no suction. We replaced it and no more problems.
Old May 14, 2008
ai6aq's Avatar
ai6aq is an unknown quantity at this point
I had same problem with mine.
Check the fuses under the bonnet and the dash, maybe the one thats linked to the fuel flow or ECU may be gone. If not, u mite need a new fuel pump
Old Jun 10, 2008
TurboB20's Avatar
Cool I will check into the fuel pump. I checked the fuses they are all good to go.
Old Jun 16, 2008
dogcar's Avatar
dogcar is an unknown quantity at this point
Have you checked the "Main Relay"?
This latches in the fuel pump after the car starts. I have had a main relay that would let the car start and run for a few minutes, then un-latch the fuel pump.
Mr. DogCar
Old Jun 16, 2008
TurboB20's Avatar
I havent checked that yet. Where is the main relay? under the hood? location?
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
