1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Car Just Died on Me...
Old Apr 23, 2008
hookecho's Avatar
hookecho is an unknown quantity at this point
Hi, I had just got done adjusting the valves on my '93 civic DX. While tigtening the last valve cover nut (the one that has the engine ground wire connected to it) the bolt snapped off inside the nut. Well, after I was done throwing things around and swearing up a storm, I decided to take the car off the ramps and order a new bolt the next day.
Started the car up, backed it up down the ramps, got out of the car to shut the hood, and like a light switch, the car stopped running. I can't get it started again...turns over but wont start.
It may be important to note that the engine ground wire that is attatched to to the chassis and to the valve cover was not connected when I took it down from the ramps.
I don't know...could not having the engine ground wire attatched to the valve cover cause this to happen?
I'm eagerly awaiting any suggestions.
Thank you, Ryan
Old Apr 29, 2008
Neutrilizer's Avatar
Neutrilizer is an unknown quantity at this point
Re: Car Just Died on Me...
Try disconnecting and reconnecting your battery and then try starting the car. That used to happen to me, until i tightened my battery connections.
Old May 8, 2008
vengeanceasx's Avatar
vengeanceasx is an unknown quantity at this point
Yeah that ground wire keeps all the sensors and electricl on your engine grounded, whic hmeans spark plugs, injectors, o2 sensor etc. Pull the 7.5 amp fuse out of the fuse panel in engine compartment and reconnect wire, then plug fuse back in. This should solve your problem.
ChristinaVHH
May 10, 2015 03:51 PM
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
