1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Engine Swap?
Old Apr 6, 2008
PsiCivic's Avatar
PsiCivic is an unknown quantity at this point
Engine Swap?
I have a 89 Civic DX HB and i have a D16 in it with 10k miles on a rebuilt block.
should i do a K20 swap or turbo my motor and add to this one?
thx
Old Apr 8, 2008
civicninitwo's Avatar
civicninitwo will become famous soon enoughcivicninitwo will become famous soon enough
Re: Engine Swap?
Well your options are only limited by the size of your budget.
In a perfect world were we all had unlimited fundage, a k20 swap would be a perfect deal. But the life on the motor you already have is basically, just broken in. If your talking about boosting the d16, well you would (in my opinion) be a lot better off spending that loot on a b-series swap. If you were really leaning towards a turbo, put that on a b18a motor. Due to the availability of the non-vtec powerplants, these can be rounded up for pretty cheap. You could then craigslist the motor/tranny you already have to get the funds up. Keep in mind that staying in the non-vtec realm, you can essentially re-use the same engine harness,with very little modification(just adding length to a few wires) saving some cash in the end.
The k-swap rules if you've got the cash, but 9 out of the 10 folks that will read this don't.
Hope this helps,
Brad
Name:	b18 heaven2.jpg
Old Apr 8, 2008
PsiCivic's Avatar
Re: Engine Swap?
thx man it does, but what would my time difference be with a turbo on the d16 as oppose a B swap?
im also new at this whole deal but what kinda of tranny would i be looking for to upgrade too?
Old Apr 10, 2008
Re: Engine Swap?
In a B-series for the most low end torque the LS (the tranny that comes from the factory with a non-vtec {example-b18a,b18b}) In a d-series try to find a Civic Si,Crx Si tranny, or if it is in your budget, upgrade to a hasport cable-to-hydraulic conversion. The conversion makes your problems of finding a reliable used cable tranny -1. Hydraulic transmissions are a really the way to go. If you do the conversion,the tranny donor of choice 92-and up sohc civic,for d series. 94 and up integra the b series.
As far as time goes, a good tune with a turbo on a d series is a good runner.
There are some amazing things that folks have done with a d series.
But a B series can bring that little extra push without having to own a machine shop.
Hope this helps,
Brad
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
