1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 LX sedan
Old Feb 6, 2008
94 LX's Avatar
94 LX is an unknown quantity at this point
Question 94 LX sedan
Does anyone know how to remove the gauge cluster in the civic? I want to add the reverse glow gauge faces but dont know where to beging since the bezel sreatches across to the vents. Any help on this would be appriciated.
Also I just purchased a set of tociko shocks/struts & lowering springs 1.5" drop all around. Does anyone know or think I'll need a camber kit? t
Old Feb 11, 2008
civicninitwo's Avatar
civicninitwo will become famous soon enoughcivicninitwo will become famous soon enough
Re: 94 LX sedan
Hello,
I would buy a haynes manual, available @ advance auto,auto zone,etc.
This will give you visual steps to remove the bezel without breaking your vents.
As for the camber kit, I have used the same tokice strut/spring combo and have gotten better tire life from adding skunk2 upper control arms(red ones)in the front and skunk2 or ingalls in the rear. Make sure that you get the car aligned immediately by a good alingment shop that does 4 WHEEL ALIGNMENT. Just tell them what you have added on the car, so they will know. Most of the alignment machines cpu's don't account for this so your alignment guy needs to know so he can do it right.
PS-DONT FORGET! Put the dust covers that come from the stock struts(black sleeves that slide over the top of the struts) I know they don't match the pretty new paint on your tokicos, but IT WILL VOID YOUR WARRANTY if you don't. Not to mention wear your struts out much faster.
Hope this helps,
peace,B
Old Apr 13, 2008
94 LX's Avatar
Re: 94 LX sedan
Ok. So now the suspension is in, looks and rides fine exept When I turn to the left my tires seem to be rubbing against the plastic wheel wells. Which I find riduculous b/c im only using 14" tires. Does anyone have a solution for this (besides raising back to original height)?
Any help would be greatly appreciated.
Old Apr 21, 2008
94 LX's Avatar
Re: 94 LX sedan
Bump
Raiool
Oct 1, 2015 10:42 AM
thatcham
Sep 30, 2015 08:28 AM
dhuff
Sep 28, 2015 08:35 PM
rovafa2002
Sep 28, 2015 06:57 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
