1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
spedometer not working 93 DX
Old Jan 9, 2007
suby6's Avatar
suby6 is an unknown quantity at this point
HI,
My sis has a 93 Civix DX.
A couple years ago the engine and tranny were rebuilt. Ever since the spedo has been intermitent now it barely ever works. If it does work its only for a few minutes then it drops to 0 again. where should I look for the problem?
Old Jan 14, 2007
SI16's Avatar
SI16 is an unknown quantity at this point
Hopefull
The 92 to 95 s20 transaxle uses an electronic Vehicle Speed Sensor (VSS). I would start there at the VSS. This is located on the transaxle. Should be 3 wires coming off it. Yellow/White Yellow/Blue and Black. The Yellow/White turns into a Yellow/Blue behind the dash to speedo. The Yello/White turns into a Black/Yellow which taps into the PGM-FI Main relay (Fuel Injection Relay) and into an Upshift indicator light. Black is Ground. Just check to see if the connecting harness has any corrosion on the terminals. If not make sure the snap on connecter stays snapped into the connector. Then do a visual of the harness and wires to see if anything is burnt or frayed or do an ohm test if you really want (not neccesary). If everything checks out ok. I cant see it being behind the dash especially if you didnt take the dash apart. Then go to a junk yard and purchase one. Trial and error. Im not sure if you want to put an ohm meter on the VSS to test it cause the wheels have to be in motion to get a reading! I don't have the reading from a new one... If that still doesn't work its possible that when the tranny was rebuilt the circuitry for the VSS was somehow disturbed.
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
