Is this an OEM Distributor or Aftermarket?
Rep Power: 0 Is this an OEM Distributor or Aftermarket?
I got a 99 Civic Ex, Auto, D16Y8 engine.
Can anyone tell from the pictures below if this is an OEM Honda dizzy or an aftermarket one? The car isn't with me now, but this are the pictures available at the time being.
https://imgur.com/a/ny8gR <<< pictures.
This is a used distributor that was used to replace my previous failing distributor about 4 years ago. Now I am looking to replace this distributor with a new aftermarket one. It's O-ring is bad and it is leaking oil. I was just going to replace O-ring, but decide maybe it's better to replace with a new whole aftermarket distributor I found on amazon. But I cannot tell if this distributor in the pictures below is a Stock Honda one or an Aftermarket one. If it's indeed a stock Honda one, I will probably hold off in replacing it and just replace the O-ring. If it's indeed an aftermarket one, I might just replace the distributor with a new aftermarket one. Though one thing I notice is, distributors are kind of things where you only want to replace when it's bad. If it ain't broke, don't fix kind of things.
Any inputs? Thanks.
Any inputs? Thanks.
Received 1,126 Likes
Rep Power: 191 Re: Is this an OEM Distributor or Aftermarket?
cap definitely is, can't tell if the rest is.
Don't buy a new aftermarket distributor, they're usually crap.
You're better off getting a used one from the junkyard, you can always rebuild them as well
Cap is aftermarket.
Can't tell about the actual distributor.
Wire connector shell looks a bit broken as well.
Someone didn't remove it from the bracket before trying to disconnect it?
FrankenCivic
1 Post
Rep Power: 0 Re: Is this an OEM Distributor or Aftermarket?
if this distributor is still working properly and just leaking from the o-ring...why replace it...o ring for the dizzy is cheap (i'm find the complete seal kit for less than 20 USD with one simple search)...and easy...inner seals are a but more tricky but still doable...if you do plan on replacing the dizzy still...go with genuine honda...aftermarket ones are crap....
when looking for a new distributor...even if you decide on after market...find the TEC...it's the same one as OEM...
Honda Genuine Part: Distributor Assy. (Td-73u) (Tec) -
https://www.hondapartsonline.net/oem...dXRvbWF0aWM%3D
Direct replacement:
TEC Distributor #TD-74U (mind you I looked one up for my 2000 civic because it was allready loaded in "my garage" so the part number may be a little different)
https://www.napaonline.com/en/p/NND9512936
Moral of the story...if it works..don't fiddle with it...if it needs a new seal...replace the damned thing...Genuine part is almost 600...direct replacement same coding is almost 300...if you don't go with genuine at least try to find the best of the aftermarkets from a reputable market...i've been buying from napa for quite some time and trust "MOST" of their parts...i don't buy their cheaper ended stuff....
Direct replacement:
Direct replacement:
Direct replacement:
It does look like I will need to replace the distributor. If I do and if I opt to get an aftermarket one, in regards to getting a TEC distributor, would it be something like this below?
Searching for TEC td-73u at auto stores online, I can't seem to find much.
I would not buy that, $70 is way too cheap for that to be of any decent quality.
I can get 2 junkyard ones for that price and they will work better than that cheap aftermarket one.
wfernley
09-27-2004 12:02 AM
01Ex
03-08-2002 03:15 AM
