Radio constant volt wire fault
Old Jul 2, 2016
dosmastr's Avatar
dosmastr is an unknown quantity at this point
Radio doesn't work and the toggle for fresh air or recycled air in the cabin does not remember where it was set and always defaults to Fresh Air.
Its a wiring fault on the constant voltage line that powers the radio and I guess the toggle for the air flow too.
Any of you guys dealt with this before? Is there a spot where if the wire is going to break this is the first place to check.?
EDIT
I'm showing voltage on both memory and accessories lines with key both on and off. Acc line 12v on, 2v when off. Memory line .4v when off, 4v when on
Old Jul 2, 2016
Re: Radio constant volt wire fault
Constant power: Blown fuse in engine compartment box, labeled 'back up'
IDK about the recirc issue though
joe75491
Dec 29, 2015 11:40 AM
PatrickR02
Oct 25, 2015 08:08 PM
CaseysGuy385
Jan 21, 2002 08:44 AM
noodles01
Dec 28, 2001 09:07 AM
AzNmiKex215
Nov 29, 2001 08:02 PM
