p1359
Old Feb 23, 2016
Alex519's Avatar
Alex519 is an unknown quantity at this point
p1359
My car has a hard time starting in the winter and the last few days have been below 10 degrees so it's been worst none to say less but when I go to start it I turn the key and all I get is a click not a repetitive click click click just a click. but when I keep trying a few times it eventually turns over and works. well today it started working finally but it gave me a code p1359- Top dead center crankshaft position no signal or noise. anybody have an idea what the real problem could be?
Old Feb 23, 2016
Re: p1359
Figure this one out FIRST.
Starter, battery, connections, cables, etc.?
The tdc sensor code might be caused by the no-start problem. If you can get freeze frame data for that code, see if RPM was at zero when the code set.
Erase code or disconnect the battery to erase the code, then fix the starter problem and see what happens.
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
pnamajck
Oct 27, 2015 07:09 AM
Mv7fd
Oct 12, 2015 05:09 PM
Belle
Dec 20, 2001 12:44 PM
