Lurching acceleration, possible ecu problem?
Old Sep 9, 2014
rujoesmith's Avatar
rujoesmith is an unknown quantity at this point
98 civic ex, d16y8 MT, 150k
So I've had this problem for a while, after 20-30mins of driving the gas pedal gets a dead spot under 2k rpm. Meaning that the engine doesn't rev or do anything until I press enough to hit 2k rpm, then it lurches forward.
I believe it's an electrical related problem though. Reason reason being I found that while I'm driving if I put the car in neutral, turn it off, then start it back up, the problem is gone for another 20mins or so. It would seem like if it was a mechanical problem doing this would have no effect?
It is throwing a cel code: p0505 idle air control system. It's been smoke tested for vacuum leaks and the iac valve replaced so I'm not sure what could be the problem there. Anyone had any similar problems? Any input would be great
Thanks!
beveragemp
May 25, 2015 07:11 PM
cruisers10
May 12, 2015 10:46 PM
Marcus2thextrem
May 10, 2015 03:08 PM
F1wanabe
Apr 27, 2015 11:06 PM
dooner24
Apr 14, 2015 07:51 PM
