purge vale ohms ???
Old Jul 27, 2014
abzack's Avatar
abzack is an unknown quantity at this point
purge vale ohms ???
Does anyone know how many ohms a good evap purge valve should read? This is the purge vale located on the top of the motor behind the fuel injectors on a 2000 civic.
Old Jul 27, 2014
Re: purge vale ohms ???
Honda doesn't seem to think that people need to know specs like that. They want you to inspect every other little thing, but never ohm test a component. LOL
Current draw on a minor computer driven load is normally far less than one amp, so the load (solenoid valve) should be a lot higher than 12 ohms.
I'll guess it would be in the 30-40 ohm range.
What's yours measure?
Anyone reading want to check a good one on a live car?
Old Jul 27, 2014
abzack's Avatar
mine was reading between 34-35 ohms so it should be good right?
Old Jul 27, 2014
It's not shorted or open circuit, so I'd run with it.
Does it click and pass engine vacuum when power and ground are applied to it?
Ohm test the bypass solenoid.
Try to locate bulletin 13-001 from Honda, relates to shorting of the bypass solenoid internally, which wipes out the driver inside the PCM.
I googled and got this Acura version of the bulletin, but the pics are not right for your car: http://www.tegger.com/hondafaq/misc/...iag/03-001.pdf
h4ldol
Apr 24, 2017 08:16 PM
CBRBlaize
Jun 17, 2016 06:11 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Bruce2
Sep 21, 2015 08:01 PM
Jul 12, 2015 11:54 AM
