Timing
Old Mar 19, 2014
davemanjam's Avatar
davemanjam is an unknown quantity at this point
Timing
OK so I'm doing the head gasket/Timing belt on my 98 Civic LX.
My question is this:
In getting the crank pulley bolt loose I've lost track of where TDC is on the Crank pulley in relation to TDC on the Camshaft...
So, does it really matter?
When I put it back together I will make sure they are both set at TDC, and will make sure the distributor is correctly positioned so that the valves are closed on Cylinder 1 when firing piston 1. (Rocker arms loose on 1, stiff on 4). I will also rotate the crankshaft by hand to make sure nothing bangs.
Is there anything else I should/can be doing to ensure everything is correct?
Old Mar 19, 2014
mikey1's Avatar
Re: Timing
there are marks on the engine,
you should be able to align TDC even with the crank pulley removed,
after you remove the timing cover, temporarily re-install the crank pulley, then use the holding tool to rotate the crank, while your rotating the crank align the marks on the CAM to TDC,
now remove the crank pulley and check the crank marks on the engine
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
