Speedometer adjustment
Old Feb 20, 2014
Hayden_Fourroux's Avatar
Hayden_Fourroux is an unknown quantity at this point
Hey guys,
So i have a 97 Civic Ex and I wanted to increase the wheel size from 14 inches to either 15 or 16 inches. And I know that in doing this i would need bigger tires as well. So my question is would the speedometer fix itself or would I have to do it myself? Ive read both but i wanted some clarification. Thanks in advance!
Old Feb 20, 2014
Re: Speedometer adjustment
First, go to tires.com and see what "plus sized" tire options they recommend for your car.
Second, go to http://www.miata.net/garage/tirecalc.html, input the OEM tire size into "stock size" and plug in one of the tire sizes they recommend for 16s. It'll give you a percentage of how off your new tires will make your speedometer. Repeat with the other sizes until you find one that is 0% or pretty darn close.
I upgraded my wheels from 185/65-15s to 215/45-17s, and my speedometer is only off by 0.2%. Using real numbers, is my speedometer indicated 60mph, I'd actually be traveling 60.4mph. Not enough of a difference to make me freak out. If I were to drop down to 16s rocking 205/50-16 tires, it results in 0% difference. The miata.net tire calculator will be about the closest you'll get to finding a matching tire combo. Realistically speaking, it's not gonna be perfect, but it's the best tool you'll have.
When you upsize your tires and you don't wanna screw with the speedometer, you wanna aim to have the same overall diameter. That said, the various tire sizes will essentially eat some of the sidewall height to compensate. You don't wanna be that guy that gets low-profile tires because that's what the cool kids are doing
Old Feb 20, 2014
This is how I chose a tire size when I went from my stock 195-65-15 to 225-40-18.
I go through those radar "your speed is __" signs on the freeway and my speedo reads exactly what the signs flash at me.
Old Feb 20, 2014
Sweet! Thanks guys that makes things so much easier
Crazygrlinak
Oct 8, 2015 05:06 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
