IAC Vale and Misfire problems - '00 with D15B swap
Old Jan 24, 2013
PaintYaCity's Avatar
PaintYaCity is an unknown quantity at this point
I previously posted this in 5th Gen but i think it should be here.
**1st post**
I got this car back in October, it drove great until December. I started having problems with high idle, within the week it went from a high idle to a fluctuating idle (800-2000rpm). That weekend i checked the codes and all it said was a misfire cylinder #1, i replaced the wires, plugs, rotor and cap, and #1 injector. The problem did not go away, then is started throwing the IACV code. I cleaned the IACV, didnt help so i replaced it.
--Even with a brand new Denso IACV(same as i took off the car) it is still throwing the IACV code and having the fluctuating idle.
~Is there anything special i needed to do when replacing?
--With the new plugs, wires, cap and rotor,fuel filter, injector in #1 - I am still haveing the misfire problem, i have done a compression check and all cylinders are at 170.
~ Could the IACV problem be fooling the computer to thinking its a misfire?
~ Can the misfire be causing the IACV problem?
~ Maybe the valves sticking?
~Maybe the distributor?
Im kinda lost at this point!
** second post **
Ok, bear with me im learning more and more abotu this car everyday.
I has a '00 ECU and Intake Manofold but a D15B block with vTec, so im thinking ill repost in 6th Gen since the problems seem to be coming from the parts off the '00
Year - 2000
model - Civic
trim - ? all power with sunroof
#doors - 2
engine - D15B - Previous owner swaped. Still has '00 ECU/Intake
trans - Manual
code numbers - 14/ 71/ 72/ 73/ 74
Old Jan 24, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: IAC Vale and Misfire problems - '00 with D15B swap
Have you checked the TPS yet?
It is one of those known causes for the symptoms you have..
Old Jan 25, 2013
i have not.
i was thinking TPS but with the money already put into it I needed a second opinion, its not throwing a TPS code its throwing IACV code.?.?
Looks like ill be cutting that damn thing off this weekend
at least its only $40
thana
Jun 15, 2020 07:05 PM
beneditti
Jan 15, 2016 12:31 PM
zaboomafoozarg
May 30, 2015 09:21 AM
rcolosi
Apr 29, 2015 07:48 PM
mievil
Apr 28, 2015 11:02 PM
