Leveling High Beams
Leveling High Beams
does anyone know how to level high beams? i switched my oem headlights out for some ebay projector headlights and the highs need to be leveled but im unsure how they are suppose to look.
Re: Leveling High Beams
hi beam hotspot should be parallel to the ground with no lift or drop. basically they point straight ahead without dipping lower like the main beam. for example if you park 25 ft from a wall and measure the height from the ground to the middle of the hi beam reflector , then go to the wall and measure up the same distance, the hi beam light spot should be shining exactly at that spot. usually those aftermarket lights have a bolt or screw you turn to aim the reflector.
one of the guides i used to aim the main light stated that i should aim the mains at 25ft 2.5" lower than what they would be up close.
so in reality it is not much higher than the mains?
yes, and actually for the lo beams its a 2.1 inch drop at 25 ft. you could even get away with 1 inch drop if car is lowered, but you might blind some people a bit more often when going over bumps. hi beam has no drop.
adamdrives
15
Aug 8, 2015 08:53 PM
