door hinge bushings
Old Apr 30, 2012
El Polloso's Avatar
El Polloso is an unknown quantity at this point
door hinge bushings
my 98 ex coupe has a terrible squeal every time the door is opened or closed. i suspect the door hinge bushings. are they difficult to replace? where can i buy a bushing kit? thanks
Old Apr 30, 2012
Re: door hinge bushings
No bushing kits AFAIK, this isn't a Blazer or some other GM product..
The hinges are welded to the body, you'd need a bodyshop to replace them.
The usual fix for noise:
Open the door.
Lubricate the door check rod and its associated parts.
Lube the hinges while you are at it.
Work door back and forth many times.
Re-lube until quiet.
Repeat for all doors.
HTH
Old May 3, 2012
El Polloso's Avatar
thanks for the info ezone, i take it you dont care for government motors?
Old May 3, 2012
Oh no, I have made a ton of money off of GMs over the years.
I just figured EVERYONE has seen GM trucks with a drivers door that barely closes and shot hinges.
The older long door/2 door cars wore out hinges in a hurry too.
In fact, all of the worn out hinge problems I have ever dealt with were on GMs.
I still own a Park Avenue, and up until maybe 2 years ago I had an Olds Calais.
I actually like many GMs.
Old May 4, 2012
WrenchHead's Avatar
DIY guy
WrenchHead is an unknown quantity at this point
Uuuuhhhhm, no. I've never seen a car with hinges welded to the body. Certainly not a Civic ... of any generation (at least nothing that's crossed my path made in any country since 1990). I don't know what kind of Civic you're working on, but my 96 and both of my 98s don't have welded hinges.
El Polloso - my '96 is doing the same thing - hinge bushings are shot and there is no service kit. You need to replace the hinges themselves. These are available through a Honda dealer. There are 2 bolts that attach to the door and 2 that attach to the body.
Best way I know to do this is to remove the front wheel and splash shield, but leave the fender on - the fender serves as a guide to align the front of the door in the proper location. It's not that bad a job unless you have fingers the size of Italian sausages and/or are clumsy, otherwise it's a pretty straightforward job and reasonably inexpensive fix.
Old May 5, 2012
I stand corrected, I apologize. Plenty of vehicles have hinges welded to the body, I wrongly assumed this would too.
I didn't have an actual 6th Civic in front of me to stare at.
They are out there, and quite common. Big 3 for sure use it.
http://www.autobody101.com/forums/vi...hp?f=6&t=17290
I have seen many over the years that were welded on the body side.
I have seen far more brands than Hondas in my life though. A blur.
Seems like all that caused real problems for me were welded.
My rememberer is gettin wore out, but my forgetter is still goin strong!
Old May 11, 2012
El Polloso's Avatar
sweet, ill price some hinges. appreciate the good information ezone and wrenchhead, you guys sure do know your stuff
juror
Suspension DIY
Jul 30, 2019 03:28 AM
glockma630
Aug 1, 2015 10:30 AM
brainwashedmc
Jul 27, 2015 10:05 PM
fordover
Jul 11, 2015 09:10 PM
ballmich
Jul 9, 2015 11:59 AM
