misfires
Old Mar 21, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
misfires
Ok so I had an issue this morning and fixed it but I thought I would pass this along so that all of you know that even those of us with a good background can have issues lol. I started my car today like normal and about 5 mins into driving was getting a mild backfire, knowing this was odd I put it to the back of my mind with the intention to check it once I had time. Almost go to work when my check engine light started flashing and the misfires got worse, sounding more like a gatling gun than a car lol. So I pulled her into my shop popped the hood and started searching. I removed the cap and inspected my wires, rotor and cap, all appeared normal. So I went to reassemble and then move onto other things when I happened to notice 1 of the bolts for the cap was slightly off angle. I inspected it and found a crack where the thread meets the shaft (damn previous owner) I then checked all 3 of them. 2 of the 3 were cracked and not holding the cap on tight. So I cleaned up then cap contacts and got 3 new bolts from my bolt supply here at the shop and now I am good to go. So keep in mind guys that sometimes the simple steps will lead to an annoying problem so check the simple stuff first, a random misfire may indicate a loose cap.
Old Mar 21, 2011
MelJ's Avatar
Trance Addict
Re: misfires
Too bad two of my bolts to my cap are broken. Lol. Guess I should drill 'em out. Although I haven't had any problems with mine. Thanks for the advice. I've been there with the small things causing massive headaches plenty of times. Never hurts to double or even triple check your work before you start the car back up.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
