Need advice on my new (used) 2000 Civic EX!
Old Mar 19, 2011
thomas94's Avatar
thomas94 is an unknown quantity at this point
So I bought a 2000 Civic EX today. 83K, sedan, $4000 OTD. It's in fine shape mechanically, but it does need a bit of work cosmetically.
1. The original steering wheel started to deteriorate (probably from too much sun exposure) so the previous owner had put on a leather cover. However, I hate the thing. It added a ton of bulk, and it made my hands sweat. I was looking at either this or this for a replacement. Advice?
2. I'm looking at a replacement keyless entry remote on eBay. I don't know if I need A269ZUA101 or A269ZUA106, since the dealer didn't include one.
3. The left side has some body damage, due to a minor wreck. It has multiple large dents on both doors, as well as some paint scraped off (complete with rust). I'm looking at getting it completely fixed. What should I expect to pay for something like that? I'm just looking for a rough figure.
4. The seams on sunroof shade are starting to fall apart and deteriorate, so I'd like to get a replacement. Unfortunately, I can't find a replacement part anywhere for some reason.
5. The seal near the windshield is split, so it rattles and drives me nuts whenever I drive above about 40 MPH. Should I just get the whole rubber seal replaced, or should I try to glue it?
Thanks in advance for the help.
I'm a bit new to all this, as I'm 16 years old.
And believe it or not, I didn't buy this car to mod it.
Old Mar 19, 2011
lazlong's Avatar
Re: Need advice on my new (used) 2000 Civic EX!
1. a) Get a new wheel at the dealer or here: http://www.hondapartscheap.com/southbay/jsp/home.jsp (expensive) Or try to get a decent one at the salvage yard: http://www.picknpull.com/default.aspx ( cheapest) Nationwide salvage listings: http://www.car-part.com/ (cheap) If you don't like any of those options, just go to the store and feel of the wheel covers till you find one you like.
2. I have no idea, sorry.
3. Body shop usually charges about $500 per door. Might be cheaper to try the salvage yard.
4. Ones in the salvage yard are probably in the same condition. Go to the dealer or the link in the first answer for a new one. Don't choke on the price.
5. replace it. Follow the link in the first answer.
Old Mar 20, 2011
thomas94's Avatar
Thanks for those links. I think I may have found couple of suitable replacement doors. I'll probably just go to Advance Auto and pick up a decent wheel cover. I might not worry about the sunroof shade, because a replacement will be >$150.
I found out that the difference between the keyless models is that A269ZUA101 has the option button for the trunk, and A269ZUA106 doesn't.
Can anyone who owns a 1999-2000 Civic EX confirm this?
Old Mar 20, 2011
Steven21's Avatar
Steven21 is an unknown quantity at this point
1. hondapartscheap.com
everything you will ever need is here
2.avital makes good replacement parts like that they are fairly cheap too
3.to fix everything and put a decent paint job on it at a local place will be about $2000
DO NOT GET IT DONE AT MACCO UNLESS YOU DO ALL THE PREP WORK
4.hondapartscheap.com
Or craigslist you can find tons of good stuff cheap on there cause lots of people have no idea what they are selling
5.DO NOT GLUE IT it never works out the way you want and looks shitty usually
go to craisglist or the junk yard for this and i know hondapartscheap.com has them too
hope this helps!!
Old Mar 20, 2011
thomas94's Avatar
What is the technical term for the rubber seal? I can't seem to find it from Honda Parts Cheap.
Old Mar 20, 2011
lazlong's Avatar
Describe where it is or take a pic- driverside or passenger? top or bottom? inside or out? Or is it the piece between the windshield and hood? Look under front windshield or hood @hondapartscheap.
Old Mar 20, 2011
thomas94's Avatar
As you're looking at the car from the front, it's on the upper right (outside) on the drivers side. It's the seal where the windshield connects to the body.
I might be able to take a pic tomorrow.
Old Mar 20, 2011
Steven21's Avatar
yeah never mind i read it wrong i dont know what its called... sorry for the post
Old Mar 20, 2011
lazlong's Avatar
Does this help? http://www.hondapartscheap.com/south...t=0&quantity=0
Old Mar 21, 2011
thomas94's Avatar
Originally Posted by lazlong
YES! That's it, thanks.
I got a few different quotes on getting the damage fixed. The cheapest was $1200, and that was with me providing my own door.
The dealer will supposedly fix it for $700-800. That might be a better route than buying two doors for $300 apiece and having to install them.
Old Mar 21, 2011
lazlong's Avatar
^^ That's a decent price especially when they'll make everything match. The dealer will only replace the damaged parts, not paint match everything.
Old Mar 29, 2011
99sicivic's Avatar
Josh
99sicivic can only hope to improve
Ebay for all the body parts cheaper than most salvage lot/junk yards
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
