Removing door panal
Old Nov 21, 2010
pinkpeeper's Avatar
pinkpeeper is an unknown quantity at this point
Removing door panal
Hi,
The lock is broken on my 1998 civic and i cant open the door at all.
Could anyone tell me in very simple terms how to get the door panal off? I have taken off the handle part and undone another screw that was behind it and im afraid that is as far as i have got. I have tried looking it up on the net but am still stuck.
Thank you
Old Nov 21, 2010
Casketglee's Avatar
Casketglee has a little shameless behaviour in the past
Re: Removing door panal
Now remove the screws from the door panel speakers and pull off the panel..
Old Nov 21, 2010
Kennykid2002's Avatar
Kenny the Ricer
I dont think you can remove the panel if you cant open the door
I could be wrong though
Old Nov 21, 2010
MelJ's Avatar
Trance Addict
When I had to fix my window, I had to remove the panel. I think you may be right, Kenny. There are clips on the bottom of the door that need to be popped out in order to remove the panel entirely.
Old Nov 21, 2010
yeah door must be open to remove the inner panel. it wont open from the inside?
Old Nov 21, 2010
Kenny the Ricer
Try this, if you took the plastic handle off the door panel, look inside for a metal rod,
Pull it towards the front of the car, and push on the door, hopefully it will open for you to take the panel off in order to replace latch assembly
Old Nov 22, 2010
pinkpeeper's Avatar
Thanks for all your help.
Iv now got the speaker out and a screw that was just above that on the panal. And im stuck again.
I have had a good look at the other door and can not see anything extra i should unscrew, but it is still very firmly attached. I also managed to carefully take off the strip at the top that had little pin things attached to the panal.
So i guess whatever is still holding it in place must be at the bottom, or possibly the sides?
I can see (through the removed handle) the rods inside and they are moving and all look ok to me, it is making the normal clicking sound.
Any more ideas? or any ideas how to get the door open?
Old Nov 22, 2010
Kenny the Ricer
I just gave you instructions that you ignored....
Try pulling on the rod that's behind the handle, and pushing on the door to open it
Your panel is held in by plastic clips, and cant be taken out unless your door is open
Old Nov 22, 2010
pinkpeeper's Avatar
Sorry maybe didnt explain properly, i did try pulling on the rod, which didnt do anything. When you use the handle the rod is moving forwards, correctly (i think), which is making me think the problem is at the other end, ie where you put the key in.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
MamaBear2015
May 18, 2015 07:37 PM
civic_gt
Apr 19, 2015 08:15 AM
