Things to Upgrade
Old Sep 5, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
Exclamation Things to Upgrade
Im new to this forum and Ive finally gotten some money to fix up my car. I drive a 99 dx and im looking to make this a car that i can have some fun in. It is the most basic model in everything so my first line of action (which im doing this week) is power windows, power locks, remote start, remote locks, and remote trunk pop after that im lost on what i should do. The engine is in great condition i just replaced the timing belt at 111000 and im at 112 now. my ignition switch is going but i found out that i had an open recall on that so im getting that taken care of too. All that stuff aside i was wondering what people would do to the car in my situation.
Old Sep 5, 2010
02civicsi02's Avatar
Low and slow!
Re: Things to Upgrade
What kind of plans you have in mind.
Old Sep 5, 2010
Steven21's Avatar
I know right now it has 107 hp in it stock. it kinda blows lol im looking to possibly pull the engine and put something different but idk what. or how that works. another thing is one of those hondata chips but once again im not sure what it is or how it works so i just need some ideas on what i could do
Old Sep 5, 2010
Low and slow!
Swap would be the best thing. Either a b series or a k series will be the best bet. There is quite alot of things to look into on swapping motors. And a tunable ecu will work just fine.
Old Sep 5, 2010
Steven21's Avatar
how do the ecu's work?
Old Sep 5, 2010
actually i hear that the B-series is easier than the k series for the 6th gen.
concerning ECU, your question is kind of very broad... hard to answer...
first define what you want - if engine swap, the answers might vary for the ecu.
Old Sep 5, 2010
Steven21's Avatar
hmm well ive heard of a few people putting a k24/k20 swap and that those put out 240 hp raw but couldnt find anything to prove that true
Old Sep 5, 2010
Low and slow!
Ya the b series is alot easier to swap in the 6th gen, hell especially since the 6th gen si has a b series.
And the k series motors have put down bigger numbers than any other. And yes they can easily be putting down 240 whp. I am going to swap a k24a1 in my car basically and just have I/RH/E, kpro and vtec killer setup and be running 210 whp and thats on a stock setup. The best k series motor is the k24a2 and the second best is the k20a2. Those are more expensive than the rest. The third best is the k24a1 which is 600$.
Old Sep 5, 2010
Steven21's Avatar
i mean i dont really want to spend more than 2500 on an engine so how much would the k24a2/k20a2 be? Im not too concerned with it being a pain to swap ive got some friends that will be able to help with it. another thing i am kinda concerned about is mpg right now im getting like 33 and i like that haha but would i be taking a big hit with a swap
Old Sep 5, 2010
Low and slow!
I know a dealer that sells k24a2 for like 1800 shipped to your door and they are legit. After that you got to think it will be bout 1500 more for all the stuff to swap it in. The k20a2 is very expensive. The lowest you can find them is 2500 and the rest are like 3500. And all the k motors get the same as you are getting.
Old Sep 6, 2010
I was reading again. probably if you use the same ecu of the engine that you put, no need for hondata. they are used when you start heavily modifying the engine, to tune it.
there's is also the reprogramming of the chip, but that you cannot reprogram by yourself. most of them is to change the fuel map, same a adjusting screws and changing nozzles in a carburetor. just gorget them if you not modying the engine.
Old Sep 6, 2010
look for suspension refreshening and mods instead.
Old Sep 6, 2010
millertime1388's Avatar
millertime1388 is an unknown quantity at this point
Hey in know this is a stupid question but what kind of problems were you having with your ignition switch? And what was the open recall? My 99 dx hatch is randomly not starting the started when i turn the key and the key really struggles with turning the ignition?
Last edited by millertime1388; Sep 6, 2010 at 09:14 PM. Reason: want to be emailed
Old Sep 6, 2010
Steven21's Avatar
Well I wanted to get the engine first then really start to mod things big time. So this is more of just a starting point than anything else. I font mind having to spend some good money to get me a car that will be reasonably quick. Putting a new engine in it is still cheaper than me buying a new car and I have no plans on doing that for sometime. But yeah my car recently started just dying while I am driving but the radio and lights still worked. I checked oine bs there is an open recall for over 1000000 hondas made around that time. So I went to my local dealership and they took care of it for free. That also helped my engine turn over a lot easier too it had been giving me slot of trouble when trying to start it
Old Sep 7, 2010
Steven21's Avatar
and where i would i be able to find the k24a2 that i could get for 1800? but another question though is if im trying to get 240 hp out my car with no mods on it would i be looking to get a k24a2 or a k24a4 block with the k20a2 head?
Old Sep 7, 2010
Low and slow!
Carparts.com you can find them for cheap. There are some car forums that sell them but not sure how much though. And you will not get 240 hp with any 4 cylinder honda motor stock with no mods sorry. The k24a2 has 200 hp and 176 trq which is 178 whp and 150ish trq. The k20a2 is 200 hp and like 140ish trq which is 178 whp and 120ish trq or something. And you do not want the k24a4 you want the k24a1 if you get one of them.
Old Sep 7, 2010
Steven21's Avatar
so what your saying is k24a1 over the k24a2?
Old Sep 7, 2010
Low and slow!
I was just saying get the k24a1 over the k24a4. The k24a2 is the best choice.
Old Sep 7, 2010
Steven21's Avatar
alright and how about k24a2 or k20a2? and if i just got one of those would it even be worth it to try and do a k24/k20 swap? or should i just leave them alone?
Old Sep 7, 2010
I think you still 1k short... 3500 total with luck...
Old Sep 8, 2010
Steven21's Avatar
well i dont want to spend a lot more but i know that if i want something nice im gonna have to spend the money and 3500 is not out of the question
Old Sep 8, 2010
Mad Dog Tannen's Avatar
I would get a stereo. The engine you have will last a long time. Hondas don't go fast unless you invest an ungodly amount of money in them. It's just not worth the time, money and effort in my opinion.
Old Sep 8, 2010
Steven21's Avatar
Yeah i already got one lol im putting in power windows power locks remote start and a remote trunk pop this weekend so thats about 600. after that the only thing it needs is some minor body work and some new paint. im just looking to make my car more like a car than a lawn mower
Old Sep 10, 2010
Benny88's Avatar
Benny88 is an unknown quantity at this point
If u stick with a B series swap, it will fit straight in, on the original mounts. K series u will have to upgrade and change mounts, quite a bit more expensive! its also a bit heavier, so depending on ur suspension setup it might throw out the balance!
Im swapping out my D16y4 for a B16a, been talkin to ppl for 6 months now, they say its da better option, but if u want more HP the K series, but will cost over 4g
Old Sep 10, 2010
Steven21's Avatar
i bought a k20a2 block and head with 37k on it yesterday for 300 with shipping
they just need bored to the next piston size so i think over the next year im just gonna slowly rebuild this engine and i found a rsx type s tranny to go with it at my local junk yard for 1200 with 47k on it which i thought was a bitchin deal lol so im prepared for it to be a pain but i want to drive this car forever and my girlfriend does not believe that i can so im making some upgrades to prove her wrong lol
Old Sep 14, 2010
Benny88's Avatar
Hey bro, thats a mad price! yeah prove her wrong man, be great when u take it out for the first time!!! u gonna slap a turbo on, or leave it as is? already pretty powerful.
Be awesome when its finished! good luck bro
Old Sep 15, 2010
Steven21's Avatar
Well i was told that a turbo would be too powerful for my car so im not sure what im gonna do with it just yet. i originally planned on having one but if someone can let me know that it wont be too powerful for sure i will definitely be adding one
Old Sep 15, 2010
Low and slow!
You can definitely put a turbo on a k20a2 and be fine. You can run bout 8 psi and be running bout 280 whp with stock internals. Run bout 12 psi and be hitting bout 310 whp stock internals.
Old Sep 15, 2010
Steven21's Avatar
and that wont cause an issue with my traction?
Old Sep 15, 2010
Low and slow!
It will but thats always going to happen if you jump up and good 100 hp. You will just need to get a different set of tires.
