well the other day i went to start my car. a few seconds later smoke came out of my dash so i quickly shut the car off open doors and to clear out the car. you could tell by the smell it was burnt wires. i gave it a min and started the car it started no smoke great so i took off then i looked at my speedometer it was goin nuts so i thought ok its just been grounded. next day i got home took apart the dash. found the burnt wire, turns out it was my ground for my cigar light wtf right well it cooked the hole wire all the way though the harness. i checked the speedometer wire it was fine so i ok w/e next day on way to school i got on it 1st gear was normal 2 nd was fine till i hit about 5k and it just boged down i lay off the gas real guick and got back on it nothin i was still slowing down i shifted into 3rd and it took off till about 4-5k and did the same thing. i dont no if it does it in 4 and 5 yet but i will find out toamow. i can realy use some help. thanks.
well i pulled the codes up in class today and here is wat i got. p0135 o2 sensor circuit malfunction, p0141 o2 heater cirtuit malfunction, and p1298 eld high voltage. now i did some test and some searchin and it seems as if my eld is bad.
- May 3rd Sunday - Touge.ca Shannonville Full track event 5:30-8:30pm! #2 of 20+ Events
- 99 hatchback with 98 b18c1 obd etest problem
- D15B2 Tachometer problems and ecu keeps going into limp mode
- I FINALY GOT MY CAR BACK
