Engine quits while driving
Old Oct 5, 2009
cueist63's Avatar
cueist63 is an unknown quantity at this point
98 Civic LX. While driving last week engine just quit on me, tried 3 times to restart and immediately stalled, let it sit for couple minutes and restarted ok and ran fine. Changed the fuel filter and four days later it quit on me again while driving. Am replacing the main relay today and hoping that fixes it. Will keep you all posted.
Old Oct 6, 2009
cueist63's Avatar
Re: Engine quits while driving
Put in new main relay today and it quit on me again about an hour later. Any one have any ideas about what is causing it to just quit running? It will start back up after I let it sit a few minutes.
Old Oct 6, 2009
does it die because the idle is dropping too low? or just sudden engine fail.
Old Oct 7, 2009
cueist63's Avatar
It just suddenly cuts off all together. It's at the shop now and the mechanic
is going to test for bad crank or cam sensor.
Old Oct 9, 2009
Apathy's Avatar
Apathy is an unknown quantity at this point
When that happened to me I needed new spark plugs
Old Oct 9, 2009
ssclayton10's Avatar
ssclayton10 is an unknown quantity at this point
is it a manual?
Old Oct 9, 2009
Apathy's Avatar
nope. automatic
Old Oct 12, 2009
unconfused's Avatar
unconfused is an unknown quantity at this point
Unhappy Re: Engine quits while driving
I have this same issue on my Civic.
1998 Honda Civic LX
manual transmission
It used to 'hiccup' while driving. Dash warning lights would flash, but the car would keep operating. In the past few months that 'hiccup' would result in the car stalling. I could leave it off for 1-2 minutes and then it would start again.
It doesn't seem to matter what gear it is in or what speed the car is going.
I've had it at a garage recently but they could not seem to reproduce the problem. They thought that it might be related to Recall ID# 38930:
http://www.internetautoguide.com/aut...073/index.html
Recall Summary
ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES, ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS STARTED.
Consequence
WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
However my VIN was not part of this recall. The garage I took it to replaced this part, and I still have the same issue. However, now it is somewhat 'worse'. Now there is no longer any 'hiccup'. I'll be driving and the engine will suddenly quit without warning.
I'll keep you posted. Any suggestions are welcome.
Old Oct 13, 2009
cueist63's Avatar
My mechanic found that my distributer and cap were defective, he replaced them and put on new ignition wires last Friday, so far so good.
Old Oct 15, 2009
hb pickup's Avatar
hb pickup is an unknown quantity at this point
Ignition! Hell I was going with fuel delivery
Old Oct 22, 2009
cueist63's Avatar
It quit on me again while driving on Tuesday, back to the shop this morning.
Old Oct 26, 2009
cueist63's Avatar
Sometimes when I first start the car it will run for about half a second and die, might do this once or twice in a row and then it starts fine. Bought a new ignition switch yesterday on ebay so will see how that works out.
Old Oct 27, 2009
sylver's Avatar
sylver is an unknown quantity at this point
Check the Oxygen sensor. My engine light just turned on 3 days ago and the engine almost quit today while I was driving. AutoZone said it was the a/f sensor. I'm taking it to Midas tomorrow.
Old Oct 29, 2009
hb pickup's Avatar
Anybody check fuel pressure? The manifold pressure sensor? Idle air control valve?
Old Nov 2, 2009
marek91's Avatar
marek91 is an unknown quantity at this point
check your fuel pump
Old Nov 2, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Same problem with my ex girlfriend's car over the weekend. She called me when it happened and I thought fuel delivery as well. Then she brought it to a shop the next day and he said it's the distributor.
Check your timing to see if something got adjusted there while fooling with the distributor. Also turn the key to ACC and see if you can hear the fuel pump coming on. If not that it could also be the fuel pump relay.
Old Nov 3, 2009
cueist63's Avatar
I called the honda dealer yesterday and there is a recall on my ignition switch, goes in today to be replaced. The one I bought on ebay didn't fit.
Old Nov 3, 2009
DeX's Avatar
DeX
Canadian, Eh!
Can you explain it in more detail exactly what the problem is?
Old Nov 6, 2009
slow hatch's Avatar
slow hatch is an unknown quantity at this point
I had the same prob and it got more frequent till i took my ign switch out and you can seperate the two pieces and find the contact point corrode i sanded them down a little and it worked for a few months then started again. sure enough took it apart and it was worn down to nothin so took one out of another honda at the junk yard and has been fine for the last 8 months.
Old Nov 6, 2009
well according to the recall that guy posted about the electrial problem i mean if you have too many watts flowing through your ignition switch it sounds like to me its nothing that a simple relay cant fix. but idk.
Old Nov 7, 2009
cueist63's Avatar
Looks like problem solved. Called Honda dealer and there was a recall on my
ignition switch. Had it replace at dealer for free on Tuesday, been fine since.
Thanks for all the help.
Old Nov 7, 2009
cRaZyTrOy48's Avatar
cRaZyTrOy48 is an unknown quantity at this point
i have the same exact problem it only happens to me either wen its too cool outside or wen it has low gas my car is automatic it only turns off wen the rpm's go down to 1 i did a diagnostic and found out i have throttle malfunctions and bad oxygen sensors if that helps..
Old Mar 21, 2012
29stitches's Avatar
29stitches is an unknown quantity at this point
Try replacing a main engine relay.
The part is: BWD Intermotor Relay R4803
I had this problem with my 1998 Civic LX sedan 5spd.
It went on for an entire a year. I would be driving along and my car would randomly shut off. When it first started happening it would start up right away. But then it would take longer and longer to start up each time. Sometimes I'd be stuck on the side of the road for 5-15 minutes before it would start up again.
So I started throwing new parts into it, one at a time until the problem was finally solved; spark plugs, wires, distributor cap & rotor, the entire distributor, starter, battery terminals, battery, and fuel filter. Even after replacing all of these parts I still had the same problem. Finally I replaced this relay 6 months ago and its worked great ever since.
I was ready to sell this car because of this problem... But now with all new electrical system. There's no way I'm selling this Hoddy
Old Mar 29, 2012
Spiffy_B's Avatar
Spiffy_B is an unknown quantity at this point
Check your o2 sensors, upstream and downstream or whichever one your check engine light says it is (thats if it's on). I recently found out two things, if you need new o2 sensors your civic will run like crap. Rough idles at lights and may even cut off just like how the OP said. I also learned not to buy those cheap ebay or rockauto $30 o2 sensors, mine only last a few months and now I'm back to these bad running conditions. Thank goodness that I'll probably be back working for Autozone in a couple days.
Old Apr 24, 2015
jampowers's Avatar
jampowers is an unknown quantity at this point
Thx. for this info. I've had exact problem on my 1998 Civic 5-sp. Will try the relay to resolve problem!
Xuhme
21
Aug 7, 2023 03:40 PM
mikemc422
Aug 9, 2018 05:41 PM
crowtoo
May 11, 2015 06:50 PM
smmahan
Apr 15, 2015 08:17 PM
crazydragon
Nov 7, 2001 05:13 PM
