96 EX seems to lack power
Old Sep 27, 2009
wingnut's Avatar
wingnut is an unknown quantity at this point
Cool 96 EX seems to lack power
Recent tuneup including a igniter and coil. It had been missing under load. It doesn't miss anymore. I have set timing a couple of degrees more advanced than what it calls for. Engine has 90,000 miles and sounds great.
When accelerating,this is a manual trans car,it seems to be holding back and you sense a slight surging at lower RPMs{between 2to 4 grand}. It seems to run fine when you get to where the V-tech takes over. I would think it should have more power in the lower RPM range. Maybe I'm expecting too much. I don't feel I have a fuel problem. No check engine light on. Has anyone had similar experiences like this? Thanx,Tom
Old Sep 27, 2009
Re: 96 EX seems to lack power
is the clutch slipping? maybe its time for a new one. does it grab right away or do you feel like its lagging...
Old Sep 27, 2009
wingnut's Avatar
Gearbox,
The clutch isn't slipping. The Rpm's are steady. Just seems like almost a flat spot in the power range. Tom
Old Sep 27, 2009
04 Honda Civic's Avatar
maybe check compression on the cylinders? Just a guess I dont know
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
JDMnoob
Aug 2, 2015 02:38 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
