Short ram intake or cold air intake???
Old Aug 14, 2009
familyguycivic's Avatar
familyguycivic is an unknown quantity at this point
Pros and cons help me out plz
Old Aug 14, 2009
zXeX's Avatar
zXeX is an unknown quantity at this point
Re: Short ram intake or cold air intake???
Short ram will intake engine heat, more likely to get "heat soak" .. cold air is obvious, but you risk water intake, though not too likely with a decent trap, just avoid Deep waters..... Short ram = cheaper , cold air = more $$$ .. for a decent setup that is. There's prob' more, but I need to get going on some errands...
Old Aug 15, 2009
ilikesnackpacks's Avatar
ilikesnackpacks is an unknown quantity at this point
Short Ram
Pros: Cheaper, no risk of waterlock, easier install, easier maintance
Cons: Pulling air from the engine bay, no real advantage over cold air
Cold Air
Pros: Pulling cooler air from outside the engine bay
Cons: Risk of waterlock, more difficult to install and maintain
You have to ask yourself what you're trying to accomplish. If this is your DD, you're probably better off buying a short ram. The gains are minimal with each. Also, if you're running a D series motor, an expensive intake is a silly mod. I'd save the money and go with a short ram if I was in your shoes.
Old Aug 15, 2009
sweet thanks guys it is my dd so i will probably get a short ram now
MyOtherRideIsBritney
Bolt-on Engine Performance
Dec 14, 2001 04:05 PM
JDock
Dec 5, 2001 11:52 AM
808specifxz
Nov 17, 2001 10:39 PM
onelifetolive
Nov 10, 2001 10:58 AM
Hobby2K
Nov 9, 2001 04:08 PM
