Windshield washer
Old Jul 28, 2009
cb450sc's Avatar
cb450sc is an unknown quantity at this point
Windshield washer
My windshield washer on my '98 LX barely shoots out the fluid. Today I am going to check for any kinks and maybe runs a thin wire through the line to get out any gunk. Is the washer motor located beside the washer fluid tank? Do I have to remove the bumper or wheel well plastic to get at it?
Old Jul 29, 2009
sql_civic's Avatar
Re: Windshield washer
yeah, the motor is behind the fender near the fluid resovoir.
Your squirters are probably clogged. See how well the fluid pumps out by disconnecting the hose.
Old Jul 29, 2009
cb450sc's Avatar
Thanks sql civic
Old Jul 29, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
My windshield wiper buds were keyed out 2 weeks ago. -_-
Old Jul 29, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
TOTALLY agree with SQL again...I've had mine clog up a few times. Usually high pressure spray directly into them clears the problem...if not, I have used a pin.
Good luck.
Old Jul 30, 2009
cb450sc's Avatar
Well I cleaned out the lines and used both a high pressure washer and a pin on the nozzles. I put the high pressure washer into the reservoir and cleaned it out as well. The drivers side is now working fine and the passenger side is better but will only shoot a single spray about a third way up the windshield. The drivers side fans out the spray across the windshield. I think I will replace the nozzle on the passenger side to see if it makes any difference. Thanks for your help.
Old Jul 30, 2009
CraigW's Avatar
Take the nozzle out and soak it in vinegar, That may clear it.
Old Mar 9, 2014
Drope8's Avatar
Drope8 is an unknown quantity at this point
I have the same problem in a Civic 2000 i just bought... no fluid pressure through the nozzles. Just finished cleaning the lines and put a brand new "used pump" (I found out the pump was missing when my daughter said it didn't work). Can it be the pump is not good?
Old Mar 9, 2014
Poopies's Avatar
Super Moderator
Does the pump make any noise when you try to use it? Did you try squirting the fluid out of the hoses?
SidCivic
44
Oct 12, 2017 03:39 PM
dlg1985
Jul 23, 2017 10:03 PM
h4ldol
Apr 24, 2017 08:16 PM
carid
Aug 8, 2015 05:05 PM
