'97 3dr DX Stalling
Old May 14, 2009
sfrankel's Avatar
sfrankel is an unknown quantity at this point
'97 3dr DX Stalling
Two weeks ago, I went to start my car, and it threw me the check engine light. I reset it, and then it did it again. At the same time, the car started to stall on me occasionally when I came to a stop sign. I checked the error code p0135 and ordered a new o2 sensor. When I went to replace the sensor, I saw the exhaust manifold/cat converter was cracked right where the 1st o2 sensor threads in. I had a guy in a shop weld it, and then I went and replaced the sensor. All was good, until I was coming to a stop at the end of an off ramp to the highway, and the car stalled again. Arrg!! I thought I had fixed the problem. Any body have a similar experience or know what might be the problem? Thanks for your help.
Old May 19, 2009
sql_civic's Avatar
Re: '97 3dr DX Stalling
Did you reset the ECU when you replaced the O2 sensor?
Old May 21, 2009
sfrankel's Avatar
Yes, I did reset ecu. Seems to have stopped stalling for now, but the mystery continues. If anyone has any thoughts, please let me know.
Old May 22, 2009
sql_civic's Avatar
It could be that your IACV is clogged. Try removing it and spraying it clean with brake cleaner if the screen is gunked up.
SimpleUser
Apr 24, 2021 02:54 AM
2.0.0.2
Sep 14, 2015 06:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Valkman
Aug 13, 2015 04:19 PM
